The spindles came without the requisite holes for the cotter pin.?Aftermarket??? Is it even possible to drill a hole(size?) thru the threaded part of the spindle so a cotter pin can be used with the castellated nut (I envision broken drill bits)OR can I use a Nyloc nut and still back it off the 1/2 to 2 flats required for the 4 degree end float and possibly use, if necessary, red or blue Loctite in lieu of a cotter pin?
