TR2/3/3A Tr3 trunnion
ekamm
Ok, I may be little daft but I can't figure out how to get the trunnion off of the vertical link. The work shop manual says to remove it.
I'm sure that pretty much everyone knows this one.
Banjo
Take off the steering stop bolt, then unscrew the trunnion from the link.
DougF
There is a stop bolt that needs to be removed. Then just unscrew the vertical link from the trunnion. One side is left hand thread.
Thoroughly clean all of the old grease and gunk out of the trunnion.
TR3driver
Great Pumpkin - R.I.P
On TR2-4, both sides are right hand thread. The "handed" trunnions & vertical links didn't start until TR4A.
Also note that the collar on that stop bolt is actually an adjustment. You might want to mark it's position before removing it. I have to adjust mine inwards a bit to keep the tires from rubbing on the sway bar.
ekamm
ekamm
Thanks I got it off. Thanks for the adjustment advice I never would have noticed the eccentric spacer. I'm not sure how it was adjusted I had it off before reading this but will look at the other side to see how it is. I think that the trunnion is original as it has the castelated nut rather than the lock nut? It needs to be replaced, but when I got the car from my dad there was a box of goodies including a couple of new trunnions.
TR3driver
Could be, but the ones I installed in 2009 also came with castellated nuts. In fact I am going to insist on that in the future, since one of the nylocs was missing on my TR3A when I stripped it. I just don't have a lot of faith in 'nyloc' nuts any more; this isn't the first time I've had them back off. There appears to be a good reason why Triumph only used them in some places and not others.
Don't forget, if the trunnions are worn, the outer bushings in the lower A-arms will be worn too. If you replace those bushings, you'll need to ream them to size after installation. My preference is for a fixed reamer, as I can never get a decent finish with a cheap adjustable reamer (and can't afford a good adjustable reamer
). Enco will sell you a "chucking" fixed reamer for under $20.
https://www.use-enco.com/CGI/INPDFF?PMPAGE=70&PARTPG=INLMK32
ekamm
ekamm
I'm not sure if the new/old ones that I have at home are for a lock nut or not. I'll look as soon as I get a chance. Would it be wrong to use a castle nut on one that is designed for a nylock? Tighten them to the correct place and drill for a split pin.
TR3driver
Should be no problem as long as you can drill on-center. I'd want to use the drill press and a center drill to start the hole.
K TR2/3/3A TR3 Trunnion Question Triumph 2
Willie_P TR2/3/3A Trunnion Installation - TR3/4 Triumph 7
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
ekamm TR2/3/3A tr3 trunnion bushing help Triumph 2
K TR2/3/3A TR3 thrust washers wishbone arm to trunnion ? Triumph 6
K TR2/3/3A More TR3 Trunnion Questions Triumph 4
K TR2/3/3A TR3 Trunnion to bushing clearance...... Triumph 2
G TR2/3/3A TR3 lower outer trunnion Triumph 4
PeterK TR2/3/3A TR3 Trunnion needed Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
