TR2/3/3A TR3 Trunnion Question
karls59tr
Bronze
When a trunnion is replaced, and everything else is OK with the front end ,should there be any play in the front wheel if the car is jacked up and you grab the wheel from the top and bottom and wiggle it? In other words should there be any movement there?
TR3driver
Great Pumpkin - R.I.P
Only a very small amount, practically undetectable.
Unless you've followed the original workshop manual and set the bearings to 1-1/2 to 2 flats loose. That will leave enough play to notice. The later manuals say only 1/2 flat.
On my 59, I eventually traced the play to the spindle being out of round where the inner race of the outer bearing fits onto it.
CJD
My '60 had the wrong bearings installed...they were larger than the spindle. Gotta love PO's. We'd have nothing to do without 'em!
Willie_P TR2/3/3A Trunnion Installation - TR3/4 Triumph 7
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
ekamm TR2/3/3A tr3 trunnion bushing help Triumph 2
ekamm TR2/3/3A Tr3 trunnion Triumph 8
K TR2/3/3A TR3 thrust washers wishbone arm to trunnion ? Triumph 6
K TR2/3/3A More TR3 Trunnion Questions Triumph 4
K TR2/3/3A TR3 Trunnion to bushing clearance...... Triumph 2
G TR2/3/3A TR3 lower outer trunnion Triumph 4
PeterK TR2/3/3A TR3 Trunnion needed Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
