Trunnion Oiler
JImEgan
I know this has been brought up before, but here is a picture of the lubrimatic oiler with lube tube attached.
Lubrimatic 30-197
TR3driver
Great Pumpkin - R.I.P
Looks just like the one I got from Mercury Marine.
J
JImEgan
Randall, Are you the one who posted the other picture with yellow packaging?
Jim
TR3driver
Don't think so, but I guess it's possible. I remember hunting up a link, but don't recall the package being yellow.
Gliderman8
Jim
That was me... The package looked a wreck, but the oiler was fine.
Looks like the same oiler.
SkinnedKnuckles
That looks like the easy way to go. I ended up with a mini grease-gun with plunger from Harbor Freight. Pull the plunger back, fill with oil, screw it back and release the plunger, and it works without leaks. Just don't decide to press the plunger, or it will leak....
F Trunnion Oiler Triumph 23
DNK Trunnion oiler Triumph 10
B Trunnion oiler Triumph 8
R TR6 TR6 Trunnion Setup Triumph 5
R TR6 Lower A-arm trunnion bushings Triumph 18
Upland SuperPro trunnion bushings Spridgets 0
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
J Top Trunnion Bushing Fit Austin Healey 9
F TR2/3/3A Trunnion bolts Triumph 11
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
J TR2/3/3A Trunnion Install Triumph 3
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
G TR4/4A Well...another stripped trunnion Triumph 8
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
B TR2/3/3A Dimensional discrepancy in Moss trunnion parts Triumph 0
B TR2/3/3A trunnion bush clearance Triumph 2
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
C TR5/TR250 Trunnion Installation Triumph 3
maxwedge5281 adjustable trunnion Austin Healey 15
B TR2/3/3A Removing front trunnion Triumph 15
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
doc50 TR2/3/3A Trunnion seal Triumph 1
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
catfood Top trunnion pin removal. Austin Healey 4
S TR2/3/3A bottom out the trunnion Triumph 7
gubba TR4/4A Lower Trunnion question Triumph 8
S TR2/3/3A trunnion drama Triumph 2
S TR6 Trunnion lube Triumph 6
Gerry M TR6 Trunnion oiling Triumph 7
B Top Trunnion Bearing Kit Austin Healey 6
K TR2/3/3A Trunnion replacement done....Thanks to Forum Triumph 3
K TR2/3/3A Trunnion spindle conundrum again? Triumph 2
K TR2/3/3A Randall....another trunnion spindle issue? Triumph 5
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
K TR2/3/3A Trunnion oil/grease again? Triumph 1
trrdster2000 Trunnion torque. Triumph 16
R BJ8 Top Trunnion removal Austin Healey 8
H top trunnion too tight Austin Healey 3
kurts100 TR6 TR6 Trunnion/Lower A-Arm Bolt--Torque or End Float Triumph 8
K TR2/3/3A TR3 Trunnion Question Triumph 2
Willie_P TR2/3/3A Trunnion Installation - TR3/4 Triumph 7
doughairfield Trunnion question Triumph 27
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
M TR6 TR6 Trunnion Bolt Removal Triumph 3
ekamm TR2/3/3A tr3 trunnion bushing help Triumph 2
Jim_Gruber Refitting trunnion and .008" Spacers Spridgets 30
ekamm TR2/3/3A Tr3 trunnion Triumph 8
Bremer Trunnion pin diameter Triumph 3
