TR2/3/3A TR3 Seat Rails
Mkutz
Howdy all -- I'm about to reinstall my seats in the TR3 and was wondering which side the adjusting rail should be on? In other words, if I was sitting on the the driver and passenger side, would the adjusting rail be on either the left or right side? Thanks for any help.
NutmegCT
Good morning!
Take a look at Don Elliot's comments in this thread. And his pictures of the layout will also help you.
https://www.britishcarforum.com/bcforum/ubbthreads.php/ubb/showflat/Number/307228/
Tom
martx-5
The rails on my car have the adjuster handle toward the trans tunnel. In other words, the left (driver's seat) in on the right, and right (passenger seat) is on the left as sitting in the seats.
Palmer
Were the original rails directly on top of the carpet? Mine were originally right on top of the carpet, and the seating position is very low. I'm 6'1" and can barely see over the steering wheel. I'm thinking of installing some sort of spacer arrangement to raise the seat. Any thoughts?
NutmegCT
Palmer - some folks do add a spacer under the rail for exactly the reason you mention. Read the posts in the link in my first post above.
Tom
prb51
Palmer,
Mine are directly over the carpet as shown in the pic. I'm 5'9" and can see out just fine, it sounds to me like you have a problem with your seat cushions springs being worn/collapsed.
Palmer
prb51 said:
Palmer,
I think you may be right. The seats haven't had the original springs since I acquired the car. I guess it may be time for a seat rebuild.
JohnnyMead
I ride "tall in the saddle" so I had someone make me an extra thin seat cushion. It works for me and I can pop in the original for average sized drivers.
This is what I like about TR3 technology: it is simple and adaptable.
John
Carbondale, IL
T Wanted TR3 Seat Frames and Seat Rails Triumph Classifieds 3
J TR2/3/3A TR3 Rear seat Triumph 11
B Wanted TR3 seat frames repairable Triumph Classifieds 1
tr3guy TR2/3/3A New TR3 Seat Rail Glides Triumph 3
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
A TR2/3/3A Tr3 Seat Belts Triumph 3
T TR2/3/3A TR3 Seat Questions Triumph 10
M TR2/3/3A 1956 TR3 ocasional seat Triumph 10
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
luke44 TR2/3/3A TR3 Which Seat flips? Triumph 11
B 60 TR3 Seat Belts Restoration & Tools 0
B TR3 seat frame issue Restoration & Tools 2
J TR2/3/3A TR3 seat patterns Triumph 9
M TR2/3/3A TR3 seat rebuild Foam VS Springs Triumph 7
mountainman TR2/3/3A TR3 Rear Seat Triumph 3
mountainman TR2/3/3A TR3 Back Seat Support Brackets Triumph 3
E TR2/3/3A TR3 seat track width Triumph 10
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
R TR2/3/3A TR3 seat belts Triumph 7
CCURTISS Removing Seat Track Screws TR3 Restoration & Tools 3
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
fad64b TR2/3/3A TR3 seat back padding? Triumph 1
AngliaGT TR2/3/3A 3 Seat TR3? Triumph 25
fad64b TR2/3/3A TR3 seat redo Triumph 17
martx-5 TR2/3/3A Seat Belts in TR3 Triumph 41
TRclassic3 TR2/3/3A TR3 seat comfort Triumph 3
D TR2/3/3A TR3 seat rebuild Triumph 11
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
martx-5 TR2/3/3A Problem with TR3 Seat Triumph 9
