Aloha All,
I'm having difficulty setting the ignition timing on my TR3A to eliminate heavy pinking on acceleration. I've followed the Haynes manual procedure for the initial static setting and I'm using a test light to determine the distributor position "as the points begin to open". I can't get the vacuum advance adjustment retarded to the point that it goes away. If I slowly accelerate, there is little or no pinking, but rapid accelerating causes heavy pinking. Any suggestions or advice will be greatly appreciated.
I've tested the vacuum advance with a mityvac and it appears to be working, the mechanical advance weights are free and will open.
Safety Fast,
Dave
Safety Fast,
Dave
