TR2/3/3A Red ignition light stays on...TR3?
karls59tr
Bronze
I'm pretty sure this has been dealt with before but what is the best procedure to track down this problem? Car starts and runs fine but know there is an electrical glitch somewhere.
TR3driver
Great Pumpkin - R.I.P
If it was working before, I'd probably start by disconnecting the field wire from the control box, and checking the resistance between the F and D terminals on the box (engine not running). You should find nearly zero ohms; if not then the regulator contacts are probably dirty and should be cleaned & adjusted.
Next simple test is to disconnect both field and armature (F and D) wires from the control box, and temporarily connect them together with a voltmeter to ground. Start the engine and watch the voltmeter as you rev the engine up just a bit. If you don't get 20 volts by 2000 engine rpm, the generator (or the wires to it) are bad & must be serviced.
Beyond that, I'd follow the procedures given in https://docs.google.com/viewer?a=v&p...Fm&hl=en_US
ArcticOne
Same issue with my 1968 GT6.
I started checking the generator first and discovered some problems with it. Will get that part sorted first before going to the control box.
Here's some sites I used for assistance:
<a href="https://www.rootesparts.com/id211.htm
" rel="nofollow" target="_blank">Electrical Tests</a>
Lucas Generator and Control Box Tests
Working on getting my generator rebuilt prior to seeing if there are other issues.
jb
ArcticOne
One other thing, on the generator tests I was only outputting 0.3 volts and that is why I concentrated more on the generator.
Will see if there are other problems later.
jb
TR3driver
One thing to keep in mind, a bad control box (or a short in the wires) can ruin a good generator fairly quickly. At higher rpm, the generator will easily put out enough current to overheat and fry itself; only the control box keeps that from happening. If you see over 20 amps charge on the ammeter for more than just a few seconds, you should probably shut the engine off and look for the problem.
K
karls59tr
Bronze
Well I discovered the problem. The fan belt was loose because the upper adjustment bracket bolt had worked itself out and fallen hence the glowing red light. As a temporary fix I installed a 1/4" bolt 1&1/2 " long using 5 washers on the bolt head and a lock washer and Loctite on the nut end. Anyone know what type of bolt the original is? Looks like coarse thread? wonder if it would have had a nut on it as there is not much room for one near the block. Maybe it was just screwed in? Years ago I had dealt with the other generator bolt issues so hope this is the last one.
TR3driver
Are you talking about the bolt that holds the bracket to the pump housing? Or the one that clamps the generator ear to the bracket?
Both are supposed to be 5/16" NC, 1.25" long; but the bolt into the WP housing is supposed to have a lock tab on it, while the generator bolt is supposed to have a jam nut on the other side of the generator ear. There is also supposed to be a plain washer between the generator ear and the link.
J TR2/3/3A Red ignition light stays on Triumph 7
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
M Red dash ignition light glowing very little Spridgets 16
L Red Rubber Brake Grease Austin Healey 2
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
C Spitfire Red painted engine number Triumph 3
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
AngliaGT Red MG Spotted 0
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
B TR6 Source for Carmine Red Triumph 4
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
T 1993 xj v12 red hot catalytic converter Jaguar 6
C How best to restore red script on valve cover? Austin Healey 7
M TR2/3/3A Red or Blue Loctite Triumph 1
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A generator red light deal Triumph 6
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
Joe Schlosser Red Samples Spridgets 5
Alfred E. Neuman Red MGA MkII Spotted 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Red TR3 on the Bachelor Spotted 1
HealeyRick "Cherry Red Austin Healey" Austin Healey 8
JPSmit Red Rubber Bumper Midget Spotted 0
H Red radiator guard reattachment question Austin Healey 10
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
T Colorado Red Vinyl Interior Austin Healey 6
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
AngliaGT Red Big Healey Spotted 0
Sarastro Red TR3 in Long Beach, CA Spotted 0
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
P TR6 Purple/Red wires & mystery bulbs Triumph 17
mrv8q TR5/TR250 Red 250 for Christmas morning! Triumph 10
C TR5/TR250 Red Master Cylinder Tag Triumph 4
R Donald Healey's red '53 Coupe to be auctioned Austin Healey 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
J TR6 What are Original TR6 wheels with Michelin Red Lines worth? Triumph 11
NutmegCT TR2/3/3A Service Instruction Manual [the "red book"] Triumph 3
PAUL161 Regency Red Paint Jaguar 4
S Red Fan Shroud BJ8 Austin Healey 2
PAUL161 Jaguar Regency Red Jaguar 4
PAUL161 Red Line Oils MGB Transmission? Racing 13
