gbtr6
Hi All,
I plan on a rebuild/freshen of my 6 motor. Some background:
About 15 years ago, I did a frame off complete rebuild of my 6. It came out fantastic, for an owner rebuild. I was more than pleased. The engine was rebuilt at that time as it had over 100,000 miles on it and was rumbling and tired. When rebuilt, I fly cut the head and decked the block so I get @ 9.5:1 compression. Its an early motor, '69 or '70 I think. I run HS-6's and dual exhaust, no header. Has an S-2 cam from BPNW. I also run Pertronix. Been real happy with it.
It has run great til last summer when it started pushing oil out the top. Did a compression test and #1 was zero. Rest were 120. Squirt of oil in #1 and it went up to 60. I figure rings, but could be holed piston? Anyway, I have @80,000 on it now, and feel like I should do a complete rebuild again instead of just fixing #1. I asked the same machine shop as last time what they would charge. I would bring a short block, head is good, and it would run $800- $1000 for disassembly, tanking, measuring, balancing and parts for rebuild freshen standard. Meaning no pistons or major items, just rings, bearings gaskets and the like. I would reassemble it.
I will replace the oil pump, clutch, and timing chain tensioner as well as these are wear items to me. May need to look at the cam and followers pending measurements. Could be relatively cheap insurance to just replace it now. I might get by on the clutch as I am easy on them and get 100,000 miles out of them. And that's an easy replace later if money is tight now.
Any other suggestions on this?
Perry
Perry
