948 Engine Rebuild Question
mxp01
All:
I'm doing a rebuild on a 948. This project has been on-and-off for about three years (no need to elaborate). But here are some details:
A professional machine shop did the following:
- Re-bored the engine to .040
- Installed a supercharger cam shaft and new bearings.
- Polished crank shaft, installed new bearings, installed crankshaft.
- The rear plate was professionally modified for new (1275) oil pump. The rear plate and new oil pump were installed.
- Gerard's rear scroll kit was installed.
- Installed a duel timing chain.
Hap Waldrop rebuilt the cylinder head - its ready for installation.
The machine shop set the timing.
I need to complete the engine re-assembly. I originally disassembled the engine in the USA in 2017. I laid out the parts in sequence as i did the disassembly, but I moved and a moving company gathered up, boxed up, and shipped to me in Barbados. Yesterday I installed the new pistons, rings, and bearings.
I have a sense of what to do next, but my Haynes Manual and Brookland's Books Owner's Workshop Manual don't give an exact sequencing fo re-assembly, so I'm looking for some direction. Tell me if this looks like the proper re-assembly sequence;
1. Install new lock tabs to the bottom caps on the connecting rods. Torque down.
2. Install the sump strainer.
3. Install the sump reservoir.
4. Install the tappets and pushrods
5. Install new head gasket and cylinder head
That's enough for now. but should I wait until after all this is complete before installing the distributor driveshaft?
Thanks,
MXP
M Need Advice On 948 Engine Rebuild Spridgets 7
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
B Reinstalling 948 engine Spridgets 7
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
B MG Motor - 948 parts or 1275 engine MG 1
L Ribcase transmission with 948 engine Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Michael Oritt 948 or 1098 Race Engine wanted Racing 3
Steve P. 948 distributor on 1500 engine? Spridgets 4
livinginthepast Anyone have a worn out old 948 engine for sale? Spridgets 9
aeronca65t 948 engine Spridgets 9
Ohiobugeye 948 cc on An Engine Stand Spridgets 17
D Swapping 948 for 1275 engine Spridgets 11
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M Vacuum Line on a 948 Spridgets 4
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M 948 Pulley Nut Size Spridgets 1
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
