Are there any of us with 948 builds left?
SD Bugeye
Wondering if there are any 948's out there? Or have they all been shelved?
bulit mine 13 years ago now.
.30 over with Isky mm32 cam and chrome moly push rods and lifters
12G295 head massaged a little and hardend seats.
also has mainflow exhaust header and pipe muffler
Pertronix igntion - dizzy
HS2 carbs shorty in the air cleaner stacks.
5 speed Datsun conversion
any others out there?
Brian_James
948 .040 over. Pretty much stock with points distributor rebuilt by Jeff at Advanced, and twin HS1 carbs rebuilt by my dad in his garage. Had it out yesterday for the first time in months, and it started right up.
Brian
drooartz
Too many mountains here for the 948 I'm afraid. Tried it for a while with my first Bugeye, but just couldn't cut it out here with the elevation and steep grades.
aeronca65t
I drove this one twice this week.
It's a '73 RWA Midget that I bought as a parts car (the 1275 engine went in my racer). The tub was real solid (only 20,000 miles) and I hated to chop it up so I threw on some old fenders and an old top I had. Then brush-painted it and fitted it with the original 948 engine from my 1958 A-35. Low compression, single-carb with 35 horsepower.
I have about $300 in it total. It's a challenge to keep up with normal cars......have to plan ahead a lot. But it's fun too.
nomad
Nial...that's an impressive car for a brush paint job and $300 invested!
Mark Haynes in Colorado has an impressive BE with a hot 948. [In the mountains, Drew!]
Kurt.
Gundy
That wheel treatment is one of my favorites. Well done.
AN6-TX
I run a 948 in my '62 AN6. Original engine with no mods. Have a spare from a '59 AN5 in the garage "just in case"...
SD Bugeye
SD Bugeye
28,000 miles on mine now
super dependable so far but have had some odd issues
had a oil filter split that was a mess glad I bulit my alarm system on that one.
Alternator belt broke that was on me I knew. The crank pulley was to worn but at the time could not find a good one.
other than that it's an awesome flat land flyer
true it's no 1275 but heck if there was such thing as numbers matching this would be one not that it matters
its for fun not a show going trailer queen.
My first memories of a bugeye is standing on the seat hanging on to the windshield frame as my mom flew thru the streets of Veirzon France
i like the shapes on this car and the MGA a series of endless loops I feel two of the nicest looking British cars ever made.
SD Bugeye
SD Bugeye
Very nice!
the second best thing I did was the 12G295 head wouldn't think that it would make to much difference but
With the HS2 carbs oh yea they sing pretty!
markberry
My Bugeye still has the 948 and smooth case. It's bored .060 over, slight cam increase( don't know the grind or manufacturer details), ported and polished head and manifold, new hardened valves and seats, guides, springs etc., stock 1 1/8" SUs and stock exhaust manifold.
it was a lot of fun (car has been undergoing restoration since 2007). I never felt like I needed a bigger motor. I could probably get a little more out of it if I went to 1 1/4" SUs and a header (given all the work I had done on the head)
markberry
Your soooo close and looks really nice
thanks! I just need to finish bolting all the accessories on the engine, recover the dash so i can install the instruments and connect the wires, then install the wiring harness throughout the rest of the car and i should be able to fire it up! after that it's install the interior, install the windshield, and send the chrome out. but i can start road testing while the chrome is being done. having said that...i spent the entire weekend getting the yard back in shape rather than working on the Bugeye! next weekend is Mother's day....sigh.
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M 948 Pulley Nut Size Spridgets 1
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
B Reinstalling 948 engine Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
B MG Motor - 948 parts or 1275 engine MG 1
7 948 sprite chewed the number three rod bearing MG 10
L Ribcase transmission with 948 engine Spridgets 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
I Bugeye 948 ignition timing help please Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Sarastro Improved clutch on a 948? Spridgets 7
I How do you static time a 948? Spridgets 4
I Head torque questions for 948 Spridgets 6
