bugeye 948 rebuilt engine - no oil pressure,
ichthos
I had casually mentioned that I did not have oil pressure when I was talking about polarizing my generator, but I thought it would make more sense to start a new thread. I added oil where the banjo bolt goes in. I also screwed in a nipple and added oil through the oil gauge line hole by pumping it in with one of those gear oil pumps. After doing this I turned on the ignition, pulled the starter, and still no oil pressure readings at the gauge. I am going to take apart the copper line at the block and the silver line that goes to the oil pressure gauge to see if anything is blocked. The oil/temp gauge was rebuilt, so I do not think it is the problem. Is there a way to check for oil pressure without the oil/temp gauge working? I want to fire up this engine, but will not do so until I am sure I have oil pressure. Any suggestions would greatly be appreciated.
Kevin
smaceng
Kevin,
Whatever you do, do not turn on the ignition AND pull on the starter cable until you have oil pressure first. I would try filling up the oil filter with oil. Then turn the engine over with the ignition off. If that does not work, substitute a known good oil pressure gauge for the BE unit. Or you can just take the oil pressure line off of the gauge and stick it in a jar. That way when it starts to squirt, you know you have pressure.
My BE rebuild took about 30 seconds of crank before it got pressure.
Good luck,
Scott in CA
I
ichthos
Scott, I just got back from the garage. I definitely have oil pressure. I took off the oil pressure line at the fitting and had my wife pull the starter. I did see oil being pumped out the fitting. I have to go to bed already, but I will pull the lines tomorrow to see if there is any blockage. I forgot to mention I do have the rotor out, so there is no chance of it starting.
Kevin
Platinum
Take th' plugs out, too, Kev. The O/P-temp gauge is not electric so no need for iggy on to see pressure.
I
ichthos
I wasn't sure if electricity was involved, so that is why I had the ignition turned on. I have the distributor cap off too. Does taking the plugs out make it easier for the oil to circulate? When I get the pressure gauge to work, what would I do next before I start the engine? How can I ensure oil has coated everything before I start the engine?
Kevin
smaceng
As said above, take the plugs out.that's about it. I think you said that this engine has been sitting for a long time, right? I might put a half a teaspoon of oil in each cylinder. Once you get verified pressure, put everything back, plugs, cap, rotor, set the timing, check for gas in the SU bowls, get the fire extinguisher handy, open the door to the garage. Go for it.
jlaird
Pulling the plugs makes compression 0. Therefor the starter does not work as hard in fact hardly works at all also turns faster.
I
ichthos
Thanks for the info. If I understand why I am doing things, it helps me remember things better. Hopefully I will get a chance tonight to spend some quality time with my Bugeye. I already have a fire extinguisher handy.
Kevin
A Bugeye engine swap, 948 to 1275 Austin Healey 11
F Ribbed case tranny in 948 bugeye Spridgets 2
bugedd So I drove my first 948 Bugeye...... Spridgets 25
longbridgehealey generator from 948 Bugeye Spridgets 2
I Bugeye 948 ignition timing help please Spridgets 8
I Help with carb hook up for 948 Bugeye Spridgets 8
E 948 Bugeye Out of Chassis Start-Up Austin Healey 1
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
