948 sprite chewed the number three rod bearing
71MKIV
Not my engine or my overhaul thankfully.
But a friend of mine, 200 miles after a fresh overhaul.
Number three rod bearing trashed. As in blue, worn down the the shell, pieces of bearing material all over the place. Sure looks like no oil, but the oil pressure was 40 to 45 hot. The oil gallery in the crank was open. #2 was scratched, but not mangled.
I know Spitfire engines, not these little motors.
What was missed? How can there be no oil to the #3 if the gallery in the crank was open?
JPSmit
no zinc? what oil?
71MKIV
I would think if it was the oil all the bearings would be trashed. I can find out what was in today and get back to you.
ralph_s
If oil was present, sounds like a tolerance issue e.g. wrong/mixed bearings, machining issue, etc. Anyone use plastigage to check out prior to assy? Were the bearings pre lubed after assembly? Did the engine turn over freely by hand after assembly prior to start. Was oil pressure OK at turnove prior to start up?
Lots to think about
Spridget64SC
Check the condition and location of the little brass oil restrictor plugs. These occassionally will dislodge from their crank location and groove a bearing and cause a catastrophic bearing distruction. This is kind of a chicken and egg investigation. Did #3 go first or was there something somewhere else that happened and #3 was the weak link in the chain? Excessive side clearances (>0.025), oil pump issue at idle, blocked oil passage on #3 rod? Something is the culprit.
Also check to see if the rod cap was installed backwards. 948/1098 diagonal split rods can be installed backwards rather easily. Most of the time, they lock the crank down, but once in a while, not as tight as would be expected. Bearing tangs in the A-series engines are always on the same side of the rod.
Doubt it was oil type. Lubrication products are just too good and consistent today. Zinc would have only been an issue for the metal to metal interface locations, like the cam and lifters. Would have taken a while to show up there.
This was a internal mechanical or assembly related condition. A detailed autopsy is required to find the underlying cause.
HTH,
Mike Miller
71MKIV
The detailed autopsy is already underway. I will get back to you.
Thanks
CZ_Dave
Gosh, I hate it when that happens
ralph_s
Steve,
We're almost neighbors, I'm in E-town.
Hope you're staying dry today, lots of local flooding here.
71MKIV
Amazing who you find. Im actually in Leola. Staying dry so far but I dunno if I will get where i am going tonight. Dont seem fair. We're under water while Texas burns.
HTH,
Mike Miller
Thats pretty much cover anything I could add, Mike pretty much nailed anything that could have cause the failure. I would ake aprt carefully and pay close attention, like Mike said when you pull the rod cap, right tne check it orientation to see if it was installed correctly. The clearnece could hve been a isuue, did you guys check clearence in anyway duirng the assembly, blueprint, or plastigauge, was the crank or rod resized as part of this rebuild. I even measure the bearing shell thicknesses in all the motors I build, even though I never find much of a difference, +/- a tenth of thousand , but atleast I know I didn't get a mislabled bearing. Alway cehck rod side cleanrece as Mike mentioned, especially if you are swapping parts like rods and crank that never have ran together before, most of the time it's good, the 1275 motor we finished yesterday had about .012" rod side clearnece across the board, I like to see alteast .010" an no more than .020", and I have had to dress the thrust sides on connecting rods before in a belt sander to get it up a bit, but most times it fine and within spec.
Also important , A series thrust bearings can be a bit testy, I like to check my crank end float at teardown and if I see them in spec, then I reuse the thrust bearings, A series thrust bearings noramlly can last several rebuilds, and if you get new, they can often time be too tight, and need sanding down a bit to get proper crank endfloat, if any of this sounds familar in the rebuild, then pay close attention the center main as it is the oil feed for the #3 rod, so the problem could have originated there. Hope this helps
71MKIV
thanks,
I haven't made the time to get ahold of my friend, but I will try and get to it in the next day or two.
He's a preacher, so Sunday's are kinda out for this kind of thing.
Ohiobugeye Morris 948 Going into a 59 Frogeye Sprite Spridgets 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
R 948 convert to 1275 info Spridgets 13
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M 948 Pulley Nut Size Spridgets 1
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
B Reinstalling 948 engine Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
B MG Motor - 948 parts or 1275 engine MG 1
L Ribcase transmission with 948 engine Spridgets 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
I Bugeye 948 ignition timing help please Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
Sarastro Improved clutch on a 948? Spridgets 7
I How do you static time a 948? Spridgets 4
