TOBs gone wild!!
Ack!! It appears the throw out bearing in my 68 B has given up the ghost. This is my first encounter with a MGB TOB. I have a very limited amount of time for the repair so I need to be as efficient as humanly possible. I'm away all next week and then have a driving event on the 19th and the AMGBA National Meet on the 20th. That gives me 5 weekday nights (3-4 hours each night) to "git-er-done". (and Sat. if I cancel on the driving event).
Tell me the best way to go. TOB, pressure plate, clutch, pilot bearing I'll order next week so they're here when I get home. What else do I "need" to get? And NO, I don't NEED a OD trans, as much I may WANT one!! LoL Any other bits or fittings, etc? Any special or unique tools required?
I want to do this right, the first time. I have been planning on these two events since I started looking for a car this year. Missing them would be a major downer. I look forward to your advice.
bgbassplyr
Motor mounts, front transmission seal.
S
Thanks Jim. Motor mounts, check. Front trans seal a precaution?
bob67bgt
Peter, Early MGBs normally have good motor mounts. A few years back I got a few motor mounts that were so hard they sent a vibration thru the whole car. If you get that problem you will know where to look to correct it now. The front trans seal and gasket are something I always change in a car I have no history on. Its too much trouble to pull the engine again to fix a leak.( rear crankshaft seal and gasket is also something you might want to consider) I also replace the clutch fork bolt and bushing. Next is the type of clutch to use. QH are still not good and purchasing a Borg and Beck off ebay may also get you in trouble. QH boxed clutches have Borg and Beck stamped in the pressure plate. BUT they are a different design than the good old B And B clutches. The QH/later B&B clutches also tend to grab right at the end of the clutch stroke. AP appeared to be a good clutch setup but I have not used one in quite a while. I will have to start a hunt for a good replacement for B&B which WAS one of the best clutches for our little cars. When ordering parts get a spare oil line that goes from the block to the gauge and a spare water pump for your trunk parts kit. Good luck gitten'er done. Bob
Platinum
Whoa.
Bob, ya covered it. :thumbsup:
Q-H was an <span style="font-style: italic">experience</span>... production shop, THREE clutches later... UGH. Put me off Q-H. I guess they've not improved, thought (hoped) they may have.
I saw a Sachs "kit" listed and have had excellent luck with fitting them in "other" vehicles, AP as well.
S
So Moss is having a 20% off sale. Should I get what I need from there?
S
Ok...'Clutchectomy' supplies ordered from Moss. Made sure to get B&B parts. Took advantage of the 20% discount too! Parts shipped yesterday so should have them soon. Now need to get home and begin the teardown.
Platinum
Ya should have the whole thing out and on th' deck in about two hours' time. :smirk:
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
B I've Gone To The Dark Side Austin Healey 18
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
3798j Edd China is Gone Other Cars 12
kennypinkerton MGB Are my wheels too far gone? MG 8
tomshobby TR4/4A A time gone by. Triumph 10
W EtypeBrakes--fluid gone???? Jaguar 6
PATR8 Wedge Where have all the Wedge owners gone Triumph 5
Pythias Gone to the Dark Side Spridgets 21
WillR MGB Been gone to long... MG 14
pkmh Distributor rotor gone bad more than once. Austin Healey 5
glemon Off Topic Gone over to the Dark Side? Triumph 11
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
jackq MGB Found MGB roadster with a/c..owner wants it gone MG 0
T Gone fishing for first tooth Triumph 10
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
jlaird After being gone Spridgets 1
Moseso A simple oil change gone South Triumph 16
scoutll Miss Chuff is Gone - A Midget Owner, I am Not Spridgets 16
3798j Photos of Days Gone By Triumph 7
CZ_Dave Ever gone picking? Other Cars 3
equiprx XK 120 gone but not forgotten Jaguar 0
Jeepster Its all gone pear shaped! Austin Healey 8
Sarastro My Sprite is gone... Spridgets 10
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
abarth69 Gone Red this time Austin Healey 7
PATR8 the VIBRATION IS GONE!!!!! Triumph 4
Perrymip TR2/3/3A Where Had All the TR3s Gone? Triumph 9
regularman Pretty sure my overheating problems are gone. Spridgets 9
drooartz Bonnie is gone to a new home British Motorbikes 11
T Blue interior for the Bugeye - anyone gone there? Spridgets 7
T BE Quarter Elliptic Mounting Bolts - threads gone Spridgets 5
G Triumph gone...Hawaiian ? Triumph 6
R Poof....post gone....lol MG 3
vping Dead battery or Genny gone south? MG 8
D Pinto is GONE!!! Racing 17
1 Hand brake ratchet gone... Spridgets 3
Tabcon "Gone in 60 Seconds"....maybe. Jaguar 4
jhorton3 Coils Gone Bad Spridgets 5
M Chrome Trim Ring on Headlight Gone Spridgets 7
d_valentino Gone "Hollywood"...Bugeye on Entertainment Tonight Spridgets 5
d_valentino Gone "Hollywood"...Healey on Entertainment Tonight Austin Healey 4
aeronca65t Hershey Hillclimb-Gone For Good Racing 7
jlaird Dog gone it. Spridgets 11
1 Spark plug wires gone 'haywire' Spridgets 16
JPSmit unviewed posts gone FORUM Navigation Questions 10
scubabatdan Sorry been gone awhile, finally made progress... Spridgets 11
toysrrus Have I gone back in time or What? Triumph 6
jlaird Miss Agatha is gone Spridgets 15
PAUL161 Sold! 79s gone! MG 13
