'67 Series 1 Etype, Got in car to return home and noticed brake pedal was soft and went far down before stopping. Did a few quick pumps no change, went very slow in parking lot and it stopped just fine. Drove to nearby Sbucs looked under and no fluid under car. Opened bonnet and noticed rear resevoir low if not empty. Drove home 5 min and car stopped just fine with long pedal. In garage examined all around under and could not find sign of fluid. Filled empty resevoir, pumped pedal, no change in fluid level, nothing under car. Haynes diagram shows rear resevoir feeding master that then sends it down to the "slave" cylinder under the master that then sends it out to the rear brakes. Front brakes have a separate pipe coming out from this "slave" to the front brakes (other resevoir feeds this cylinder directly). 1) any ideas on where the fluid went? 2)Thought I would just bleed rears to see if doing that somehow shed some light on problem. Looks like a real finger twister to get hose onto bleed screws, maybe taking off the front shock would give better access, any other way? Thanks, Jay p.s. rear calipers the all-stainless ones
