TR2/3/3A Stator Tubes
doc50
I needed a TR3 stator tube and I found one at Macy's Garage a couple weeks ago. Came back a few days ago and couldn't find it listed. Turns out that Mark Macy's machinist is having significant health issues and has stopped making stator tubes for them.
(Hope he gets well soon).
After looking at it, I realized it's just a 3/8" OD s/s thinwall (.035) tube. Called my local Industrial Metal Supply and in an hour had a new one all made up.
I have enough extra tube to make another one if anyone needs one.
Thom
1959 TR3
#34909L(O)
CJD
The ones I've seen do have some splits that keep it centered in the steering shaft and prevent rattling. Sad about Mark. I had been planning to order one of his tubes too...
doc50
doc50
John, the slot is just a 2" cut at the upper end and the 'anti-rattle lantern bushings' are separate items....but if you don't have those,some creative use of o-rings can keep the stator from rattling around. Place them at around the 1/3 points in the shaft. They are only meant to keep the stator tube from rattling.
You can easily make up a tube using 3/8" OD s/s tubing with a .035 wall thickness.
Thom
CJD
Thanks, Thom. I'll check it out...I assume The bushings can be slipped off and re-used. Definitely cheaper from the steel supplier!
doc50
doc50
John indeed, the lantern bushings can be re-used.
Marv, I don't know about your 3000....but I'll guess that the designers didn't want to think too far outside the box when creating that car.
You may find that the same tubing will work for you.
Thom
Geo Hahn
John indeed, the lantern bushings can be re-used...
You're probably trying to be politically correct - but the common descriptor of 'Chinese Lanterns' is certainly apropos for this item. I don't know if anyone offers them these days - I gave away my extras years ago. Would be rather ironic if you could get some actually made in China.
sp53
If you want one delivered, Moss sells a stator tube for an Austin Healy ( 021-247) that I heard fits a tr3, but not sure
doc50
doc50
Haha, Geo, I wasn't so much trying to be PC....I just forgot what the heck we call those things. Chinese Lantern is indeed a good descriptor.
Luke, the thing about these stator tubes is they are so dead dog easy to make up. I had to buy a 10' length of 3/8" thinwall s/s ($15) and it took me 30 minutes to cut the slot with a dremel tool. Macy's, when they offered them, wanted $70. I bet any other supplier would be similar.
tedwone
I made my own stator tube as suggested in earlier comments. Instead of the factory basket springs that keep the tube from rattling, I found some thin wall teflon tubing that fits over the tube and inside the steering column. Seems to work fine.
english john
I also spoke to Mark Macey and then went on a search for Stator tubes.Revington TR in the UK sell them but only for the non-adjustable steering, but you can convert them by
increasing the slot from 40mm to105 mm for adjustable.I have just received mine and they cost 25.35 GBP plus shipping. Part number is 300515 for TR3B
english john
Sourced a stator tube at Revington TR in the UK and have successfully converted it to fit my adjustable steering on my TR3B by
extending the slot to 105mm
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
G Stator Tube Nut and Olive Austin Healey 9
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
D TR2/3/3A stator tube will not go down Triumph 0
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
M Questions about stator tube and trafficator fixation Austin Healey 31
D BT7 stator tube Austin Healey 39
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
B Stator/Traficator [Control Head] Question Austin Healey 2
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
JFS TR2/3/3A Stator Tube Wires Triumph 9
T TR2/3/3A Oil in Stator Tube ?? Triumph 5
J Stator tube lost in steering box Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
L Thread size, indicator head to stator tube screws Austin Healey 0
T TR2/3/3A Stator tube, wires stuck Triumph 15
R 100-4 stator tube Austin Healey 7
M Installing new stator tube Triumph 28
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
mgedit TR2/3/3A Stator Tube 56 TR3 Triumph 5
K TR2/3/3A TR3 - Stator Tube Rotation Triumph 4
ekamm TR2/3/3A Tr3a stator tube Triumph 15
T TR2/3/3A TR3 stator tube. Triumph 2
richberman stator tube pictures Austin Healey 10
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
S stator tube olive Triumph 4
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
A Stator removal Austin Healey 5
timbn2 correct stator tube question... Austin Healey 3
Johnny Non adjustable stator tube Austin Healey 2
TRJohn Wires stuck in stator tube Triumph 2
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D TR2/3/3A Pushrod tubes Triumph 4
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
B TR2/3/3A Tubes in steel wheels? Triumph 18
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
Michael Oritt Tubes in, Box out Austin Healey 10
Keith_M demister tubes and vents Spridgets 2
D TR2/3/3A Tubes in steel wheels? Triumph 15
R GT6 Early Gt6 Pushrod tubes Triumph 14
BlueMax Wiper Chain Tubes Spridgets 3
Got_All_4 General Tech Storage of inner tubes Triumph 4
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
