correct stator tube question...
timbn2
which is the correct one for the BN2? I have seen them as short as 12-18 in and as long as the entire steering colum. What gives?
thanx
stevebn2bj7
Tim,
It depends upon what kind of steering column you have. If you have the adjustable column you will have a two piece stator with a short piece by the steering wheel and a long one internal to the column that runs the length of it. If you have a non adjustable then there is a one piece stator that runs the length of the column. Hopefully you still have the trafficator as the replacements for the BN2 are very expensive if available at all.
Steve
Dave Russell
Yoda - R.I.P
According to the "books", the BN1's through December 1953 had two piece adjustable steering columns. Later BN1's & all BN2's had the longer fixed columns.
The fixed (long) column cars would have a narrower 1 5/8" wide dashboard slot.
hama61
Hello Tim,
In addition I can tell you, that the non adjustable trafficator has the odd looking horn push ( which will make it the longe version) and is much bigger that the one of the adjustable trafficator (short stator tube version).
Kind regards
hama 61
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
