stator tube olive
sp53
I have a question about the olive that goes on the end of the stator tube. I have some that I thought are original and they are kinda cut in half. Anyway I ordered one form Moss with some other stub and it is the same thing you can get at HD for fifty cents. I am I tripping again.
Steve
TR3driver
Great Pumpkin - R.I.P
Not sure I understand the question, Steve. The originals were definitely a different shape than the ones from HD, tapered only on one side (while the ones from HD taper on both sides). Mine are also split, but I'm not certain if they were that way originally or got broken in the process of removing them from the tube. Seems like I recall seeing one that was not split, but perhaps not.
It seems like the split gets squeezed shut where it counts (in the space between the tube and the spigot), but I smeared a little Hylomar into the split last time, JIC.
Adrio
I just finished rebuilding my steering box and both my in use and spare steering boxes has the split in the olive. I have no idea if they are all like that but both olives seem to have very clean and stright slits, so I tend to think it was made like that.
MGTF1250Dave
Aloha All,
They are designed with the split. The narrow cut allows it to seal when the compression nut is tightened, however the olive can also be removed from the stator tube when the nut is removed. This allows the control head/stator tube to be removed if necessary without destroying the olive. Without the split, it is most likely the olive would be compressed onto the stator tube and could only be removed by cutting it off. A micro saw, like an X-Acto makes a small kerf, so you can cut the hardware store offering and it may work.
S
sp53
Yes mine are split also and the one I got from Moss is split, other than that it looks the same as the HD one. I see your logic in why the split is there Dave. Thanks all and I think now I will keep the $3.00 one I got from Moss.
Steve
G Stator Tube Nut and Olive Austin Healey 9
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
D TR2/3/3A stator tube will not go down Triumph 0
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
M Questions about stator tube and trafficator fixation Austin Healey 31
D BT7 stator tube Austin Healey 39
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
JFS TR2/3/3A Stator Tube Wires Triumph 9
T TR2/3/3A Oil in Stator Tube ?? Triumph 5
J Stator tube lost in steering box Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
L Thread size, indicator head to stator tube screws Austin Healey 0
T TR2/3/3A Stator tube, wires stuck Triumph 15
R 100-4 stator tube Austin Healey 7
M Installing new stator tube Triumph 28
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
mgedit TR2/3/3A Stator Tube 56 TR3 Triumph 5
K TR2/3/3A TR3 - Stator Tube Rotation Triumph 4
ekamm TR2/3/3A Tr3a stator tube Triumph 15
T TR2/3/3A TR3 stator tube. Triumph 2
richberman stator tube pictures Austin Healey 10
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
timbn2 correct stator tube question... Austin Healey 3
Johnny Non adjustable stator tube Austin Healey 2
TRJohn Wires stuck in stator tube Triumph 2
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
doc50 TR2/3/3A Stator Tubes Triumph 12
B Stator/Traficator [Control Head] Question Austin Healey 2
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
A Stator removal Austin Healey 5
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
