TexasKnucklehead
Today I found that, in fact, I did not take everything apart on the TR3 years ago as I previously declared. While getting ready to install the steering column I realized the wires had not been pulled from the stator tube. They were broken off flush at the steering box when I got the car. When I pulled the trafficator off, the other end broke with about an inch of the 4 wires sticking out. It appears the 4 wires were wrapped with electrical tape before being stuffed through the tube. I tried everything but that inch of wire keeps getting shorter, instead of longer. From the broken end, I tried using a drill bit and drilling into the tube, hoping the entire harness would spin free. But eventually I came to the end of the bit (about 18" long). I tried penetrating oil and hammering a 1/4 rod into the drilled end. I can't get the wires to budge. Any ideas on how I might get these wires out? Melt them?
...and the trafficator hasn't been taken apart either. Just when the I thought the light at the end of the restoration was getting closer.
I am happy to entertain any ideas.
Thanks in advance, Jer
