TR2/3/3A Starter Solenoid
ckeithjordan
How can one bench test a starter solenoid to see if it works, without wiring it into the car?
DavidApp
You could wire up a Head light using the solenoid as the switch then ground the solenoid case and apply power to the contact that the starter switch connects to. The headlight is a slightly higher load than just using a meter to test the starter contacts.
Of course you could use a starter motor but would need to secure the motor.
David
dklawson
Or test with no load using a multimeter. Set the multimeter for continuity or resistance (Ohms). Check for continuity between the two big threaded terminals. You should find infinite resistance (open) with no power supplied. Now connect a battery charger to your solenoid, black/ground cable to the solenoid mounting foot, red/hot lead to the solenoid's spade terminal. You should hear a click when the battery charger is connected and the solenoid is likely to jump a bit. With the solenoid powered by the battery charger, use the multimeter again. You should find continuity (very low resistance) between the two threaded solenoid terminals.
Testing with a load like the headlight suggested above is better but the multimeter is an adequate test just to confirm the contacts are moving and closing.
ckeithjordan
ckeithjordan
Thanks guys!
R TR6 Starter Solenoid Conection Triumph 11
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
S TR2/3/3A Starter or Solenoid Triumph 13
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Crankshaft TR2/3/3A Starter Solenoid Question Triumph 13
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
H Starter Solenoid Positon Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Lin starter solenoid problem Austin Healey 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
A Starter Solenoid Question - Push vs. Non-Push Austin Healey 4
Frank C. Starter Solenoid Austin Healey 3
Hegg Starter Solenoid Buzzes when trying to start Triumph 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
