Starter Solenoid Buzzes when trying to start
Hegg
When I attempt to start my car, I hear a buzzing sound coming from the solenoid. Where should I start troubleshooting? The starter tested positive at AutoZone this morning.
Thanks!
Hegg
Dave Russell
Yoda - R.I.P
The most likely problem is a bad battery cable connection somewhere, or possibly a low or defective battery. For some reason, the voltage at the solenoid is going very low when a load is put on the system. A quick check is to see if the headlights go very low or out when you try to start. If they are not bright before trying to start, the battery is low.
Hegg
Hegg
I've got it jumped to my Falcon -- which I know is good cuz I drive it every day. I'll check the cables a bit more thoroughly.
R TR6 Starter Solenoid Conection Triumph 11
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
S TR2/3/3A Starter or Solenoid Triumph 13
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Crankshaft TR2/3/3A Starter Solenoid Question Triumph 13
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
H Starter Solenoid Positon Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Lin starter solenoid problem Austin Healey 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
A Starter Solenoid Question - Push vs. Non-Push Austin Healey 4
Frank C. Starter Solenoid Austin Healey 3
M MGB 1967 MGB starter conversion MG 6
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
