19_again
'67 MGB roadster
I am replacing my harness and when connecting to the solenoid I find the male connector spade on the solenoid to be very "loose". I can wiggle it, can't pull it completely loose but it's sloppy to be sure. This is where the line coming in from the harness plugs in, not any of the heavy connections. Plugs into the spade. I have replaced "bad" parts before only to find they were built that way, so I'm thinking this may be correct. Before the harness, she started just like a B should, instantly. Any hints?
Thanks,
Mike
PS As you can see this is keeping me awake.
Thanks,
Mike
