sloppy steering .........
heliguy
I can push and pull on the steering wheel causing the shaft to move in and out of the rack about .250 of an inch, maybe a touch more. Can i reduce this "play" just by adjusting the shims on the cap that covers the pinion gear?
Oh, its a 59 twin cam but the procedure should be the same for any mga......
thanks in advance,
Mitch
tony barnhill
Great Pumpkin - R.I.P
Contact Gerry Masterman (GEM Enterprises)...think he has a bush kit for it.
ccougill
and if he doesn't have a kit send him the steering column and he'll make one
Billm
I have a spare MGA rack that I'll sell you for $30.00,. It should be rebuilt but it sounds a lot better than the one you have.
I'm in the Seattle area.
Bill
David_DuBois
if you can move the whole steering shaft in and out of the rack, your problem is not bushings in the shaft housing. It sounds like you are missing the thrust washers on either side of the pinion gear in the steering rack. That spare rack that Bill has offered may be the only place to get those washers, they are special, hardened washers, one on either side of the actual gear. You might try Moss and Victoria British to see if they carry them.
Cheers,
Steve_S
Indeed. Bushings reduce side play in the column. While you have the rack out, you may as well replace the upper bushing. It's simply a piece of felt soaked in graphite oil. The proper felt well soaked in the right oil will last 100-200,000 miles and costs pennies.
heliguy
heliguy
OK, thanks guys. Yes, it does sound like a thrust washer problem. There is no play between the inner and outer parts, just the vertical play. I dont remember it having that much before.
Bill thanks for your offer. Im not sure if the rack will fit or not, I know the "lower" shaft is a bit longer to make up for the TC rack being mounted farther forward, and i thought the mounting part was just a bit different also. I will try to get it apart this weekend and see whats what!
cheers,
Mitch
heliguy
heliguy
WoooHooo, Problem solved! I was pushing the steering wheel in and out myself, and i could only see the first section of steering shaft and the "U" joint, and they were both moving. I got my helper to do this, and saw the my problem was the pinch bolt was not tight enough on the U joint, so thats where my Play was............I thought it strange to be thrust washers, as i was sure i put the thing back together the right way, but that was 4 years ago. Anyways, thanks for the hints, tips and offers..........they all got me thinking and now its sorted out!
cheers,
Mitch
jlaird
It's all so simple when you have the answer.
H sloppy steering box Austin Healey 19
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
BoyRacer Sloppy 100-6, 3000 door hinges Austin Healey 4
H sloppy shock arm fix Austin Healey 4
A sloppy shifter !! somthing must be wrong Triumph 7
Tabcon Sloppy cam? Racing 0
Tabcon Sloppy cam? Triumph 13
19_again sloppy solenoid connection MG 6
7 My car was wired by Pedro's sloppy brother! Triumph 17
A Sloppy Throttle Linkage..... Triumph 18
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
