Sloppy 100-6, 3000 door hinges
BoyRacer
Is there a fix for worn door hinges. I see Moss has new ones for $224.99. Ouch! Anyone have a cheaper solution?
Deleted member 19315
Get a decent machine shop to drill and ream the pin oversize. Fit new pins made from a stock silver steel. Simples.
dancrim
Too bad your not near Louisville. We could "git er done" for a couple of 6 pacs in my shop. Even $110.00 seems steep.
BoyRacer
BoyRacer
Duane, Thanks for the links. The guy on ebay has the right idea. I've got a press and a media blast cabinet, so i'm gonna give it a try myself. It appears that it is only the aluminum half of the hinge that wears. I've got a good machine shop that can drill out the holes for some new bushings. Since I've got 4 hinges that need refurbishing, I know I can do it myself for a lot less than the guy on ebay charges.
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
H sloppy shock arm fix Austin Healey 4
H sloppy steering box Austin Healey 19
A sloppy shifter !! somthing must be wrong Triumph 7
Tabcon Sloppy cam? Racing 0
Tabcon Sloppy cam? Triumph 13
19_again sloppy solenoid connection MG 6
heliguy sloppy steering ......... MG 9
7 My car was wired by Pedro's sloppy brother! Triumph 17
A Sloppy Throttle Linkage..... Triumph 18
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
