Sloppy cam?
Tabcon
I was trying to degree the camshaft today, what fun, and I noticed an abnormal amount of end play in it. Way, to much end play to be more specific, about .075".
I remember that when I dismantled the engine, the distributor/oil pump shaft was wobbly as was the cam. I didn't worry about it at the time because I was replacing the cam and the geared shaft as well. Then I realized that I decided to use the original cam instead of the Newman cam I had bought a while back. I had the original cam reground by Integral cams to a Stage 2 which I thought would work better with the build.
I have not tried installing the new Newman cam to see if this solves the sloppy end play yet, but I will most likely try this tomorrow to see if this corrects the problem.
If it does not correct the loose end play, what are my options?
Do they make bushing of some sort to place between the front of the cam and the cam bearing to take up the slack?
It's funny that the factory manual advises you to check the end play, but it doesn't address how to fix it if it's off.
Tabcon Sloppy cam? Triumph 13
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
BoyRacer Sloppy 100-6, 3000 door hinges Austin Healey 4
H sloppy shock arm fix Austin Healey 4
H sloppy steering box Austin Healey 19
A sloppy shifter !! somthing must be wrong Triumph 7
19_again sloppy solenoid connection MG 6
heliguy sloppy steering ......... MG 9
7 My car was wired by Pedro's sloppy brother! Triumph 17
A Sloppy Throttle Linkage..... Triumph 18
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
