I have a (hopefully) final question regarding mounting seat belts on my 66 BJ8. The "clamshell-type belts supplied by Moss has two clip mounts, and one through bolt mount with plastic decorative covering. They come with two eye bolts and one hex bolt. So where does each go? The pictures I've seen in the Anderson/Moment Restoration Guide seem to suggest that the eye bolts go on the transmission tunnel and the floor. That would leave the hex bolt mount for the rear fender well. But there is a two bolt fixture already welded to the inner fender well. The two don't mesh. Kilmartin sells a mounting bracket for the floor, and a chrome mount for the fender well, but neither, of course, fits the Moss belt system. So is there a generally accepted answer to the "correct" seat belt with corresponding mounting system?
