Seat Belt Problem
mdionne
Member
After removing the seat belts over a year ago and doing tons of work, I am now ready to install new seat belts. Except..........can't find the dang attachment point for end piece coming out of the recoil. I have the buckle attached to the tunnel and the recoil attached behind the seat. Where the heck does the other bolt go?
I have just put in all new interior and do not want to rip it all out. So I'm ripping my hair out instead/ Help please!
JPSmit
Mike, assuming this is a Midget (and you may want to take this to the Spridget (Sprite+ Midget board) You should have three points. The "female" end on the tunnel. The Belt recoil piece behind the headrest and the third straight below that beside the seat base. Then when you pull the belt, it does both the waist and the shoulder belt. Hope that makes sense, I can get a picture if you need it.
mdionne
mdionne
Member
Thanks everyone! Found em! Right where Ron says they're supposed to be. Only I filled them in with sealer after I welded in new floor pans. Must have said, "Sure I'll remember what those are for and where they are". Said that a lot before I started taking digital photos of everything I dismantle and re-assemble!
Thanks again!
mdionne Seat Belt Problem Spridgets 3
kyreb1862 MGB 77 MGB Seat Belt Problem MG 9
D TR2/3/3A layout for lap type seat belt Triumph 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
Michael Oritt Seat belt anchors--introduction Austin Healey 2
F TR6 Seat Belt Module? Triumph 4
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
I General TR Seat belt dissassembly help Triumph 0
I TR6 Seat belt restoration Triumph 1
C TR6 Seat belt warning bypass for new harness. Triumph 6
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
T seat Belt Buzzer Wont shut off Triumph 5
C Stock seat belt color? Austin Healey 11
B seat belt upgrade complate ! MG 1
L 1978 mg midget seat belt replacement Spridgets 3
Stinger TR4/4A TR4A Seat Belt Badge and Side Lamp Lens Triumph 8
HealeyRick Need BJ7 Seat Belt Bracket Location Austin Healey 4
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
T 3 point seat belt options in a Bugeye Spridgets 5
S Need two of these seat belt brackets Austin Healey 3
I 3 point seat belt installation help Spridgets 3
Jim_Gruber Retractable Seat Belt-Mine has been eaten Spridgets 3
Gliderman8 Seat belt parkers anyone? Triumph 2
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
T Seat belt question.... MG 4
C Seat belt guide MG 0
J seat belt intallation in late BJ8 Austin Healey 24
Tinkerman TR2/3/3A Seat Belt Mounting TR 3A Triumph 6
tweety I need a Kangol seat belt Spridgets 1
T xj6 Seat Belt Jaguar 1
rlandrum TR2/3/3A TR3A Seat Belt Question Triumph 22
Indnrdr BT7 Seat Belt Mounting Acorn Nuts Austin Healey 0
mrv8q TR6 TR6 Seat belt mounting question Triumph 3
dklawson Spitfire Spitfire - Seat Belt Anchor Bolts [Size?] Triumph 6
milemarker60 Miata Seat Belt Receiver Question Triumph 4
X Seat Belt Holders MG 5
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
A Seat Belt replace MG 3
A Break Warning Light & Seat Belt Extenders MG 3
A MG in NASCAR / Seat belt clips? MG 10
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
W Seat belt warning electricals MG 0
T Seat Belt screw Rover / Land Rover 3
