dklawson
This should be a fairly simple question. What size should the bolt be for the floor mounted seat belt anchor bolts? My car is a 1972 Spit and a previous owner damaged both weld nuts on the underbody. One has been drilled through and fitted with a large bolt with a heavy hex nut underneath. The other side received a smaller bolt and the DPO put a stainless wing nut on the underneath side.
I'd like to get the proper size bolts. I'm not opposed to using a heavy nut on the bottom side and/or welding in new anchor nuts. I'm working on the floor and now is the time to fix this area.
