TR6 Seat belt warning bypass for new harness.
ckdove
I'm installing a new wiring harness in my 72 TR6 and it just donned on me that my aftermarket seatbelts do not include any kind of warning switch to connect the wiring to. What experiences are out there for dealing with this situation? The car is being reassembled so access to everything is still possible. Thanks
TR3driver
Great Pumpkin - R.I.P
If you really want to have a functional seat belt buzzer, then you'll have to find belts that incorporate the switch.
Otherwise, just hide the wires and ignore the problem. Unlike some later cars, you just won't get the warning light and buzzer.
C
ckdove
Life without the buzzer and the light would be fine. Does the seatbelt warning system affect the ignition system, i.e. car won't start if the seatbelt isn't fastened? I know the later 74 model was complicated as things were linked together and the car wouldn't start. If I can get away with not connecting them then that works for me.
TR3driver
No, it won't affect the starter on a 72. All that happens is that the warning light and buzzer won't show the belts are not fastened. The buzzer will even still work to show the key is in the ignition (if you can find the proper door switch).
Even on a 74, all you have to do is unplug the module and put a jumper in the plug.
A Break Warning Light & Seat Belt Extenders MG 3
W Seat belt warning electricals MG 0
7 T-Series Seat belt warning switch MG 4
D TR2/3/3A layout for lap type seat belt Triumph 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
Michael Oritt Seat belt anchors--introduction Austin Healey 2
F TR6 Seat Belt Module? Triumph 4
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
I General TR Seat belt dissassembly help Triumph 0
I TR6 Seat belt restoration Triumph 1
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
T seat Belt Buzzer Wont shut off Triumph 5
C Stock seat belt color? Austin Healey 11
B seat belt upgrade complate ! MG 1
L 1978 mg midget seat belt replacement Spridgets 3
Stinger TR4/4A TR4A Seat Belt Badge and Side Lamp Lens Triumph 8
mdionne Seat Belt Problem Spridgets 3
mdionne Seat Belt Problem MG 2
HealeyRick Need BJ7 Seat Belt Bracket Location Austin Healey 4
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
T 3 point seat belt options in a Bugeye Spridgets 5
S Need two of these seat belt brackets Austin Healey 3
I 3 point seat belt installation help Spridgets 3
Jim_Gruber Retractable Seat Belt-Mine has been eaten Spridgets 3
Gliderman8 Seat belt parkers anyone? Triumph 2
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
T Seat belt question.... MG 4
C Seat belt guide MG 0
J seat belt intallation in late BJ8 Austin Healey 24
Tinkerman TR2/3/3A Seat Belt Mounting TR 3A Triumph 6
tweety I need a Kangol seat belt Spridgets 1
T xj6 Seat Belt Jaguar 1
rlandrum TR2/3/3A TR3A Seat Belt Question Triumph 22
Indnrdr BT7 Seat Belt Mounting Acorn Nuts Austin Healey 0
mrv8q TR6 TR6 Seat belt mounting question Triumph 3
dklawson Spitfire Spitfire - Seat Belt Anchor Bolts [Size?] Triumph 6
milemarker60 Miata Seat Belt Receiver Question Triumph 4
X Seat Belt Holders MG 5
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
A Seat Belt replace MG 3
A MG in NASCAR / Seat belt clips? MG 10
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
T Seat Belt screw Rover / Land Rover 3
