seat Belt Buzzer Wont shut off
timtucker
1979 Triumph Spitfire 1500, all of a sudden the seatbelt buzzer wont shut off...key off and removed still goes on and on...tried attaching seatbelts and disengaging......is there a quick fix? I cant even find the buzzer! Thanks for your assistance in this matter
pdplot
I can't recall whether it was my TR6 or my son's Fiat that came with a buzzer but I took it out and tossed it in the garbage. It was under the dash.
Gliderman8
Don't know about the Spitfire but on the TR6 the buzzer is in the passenger foot well.
Do you have a seat switch that is possibly not working (stuck in the NC position)?
glemon
Here's a wiring diagram, looks like the buzzer wires have orange stripes, but can't help you with exactly where it is located, I agree with the advice to disable it, you can decide whether you want to wear seatbelts without the annoying buzzer, had an RX7 that buzzed when you left the keys in the ignition, when you do your own work on a car you often leave the keys in as you work on it, locating and disabling that buzzer was the best thing I ever did to the car. EDIT I am an idiot, forgot to post a link https://triumphspitfire.com/images/wiring/78diagram.jpg
Andrew Mace
On earlier Spitfires with the key buzzer, the buzzer unit was up under the dash pretty far to the LH side, as I recall. Don't know if it might have moved on later cars, though. On the early cars at least, it looked very similar to a flasher unit.
D TR2/3/3A layout for lap type seat belt Triumph 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
Michael Oritt Seat belt anchors--introduction Austin Healey 2
F TR6 Seat Belt Module? Triumph 4
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
I General TR Seat belt dissassembly help Triumph 0
I TR6 Seat belt restoration Triumph 1
C TR6 Seat belt warning bypass for new harness. Triumph 6
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
C Stock seat belt color? Austin Healey 11
B seat belt upgrade complate ! MG 1
L 1978 mg midget seat belt replacement Spridgets 3
Stinger TR4/4A TR4A Seat Belt Badge and Side Lamp Lens Triumph 8
mdionne Seat Belt Problem Spridgets 3
mdionne Seat Belt Problem MG 2
HealeyRick Need BJ7 Seat Belt Bracket Location Austin Healey 4
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
T 3 point seat belt options in a Bugeye Spridgets 5
S Need two of these seat belt brackets Austin Healey 3
I 3 point seat belt installation help Spridgets 3
Jim_Gruber Retractable Seat Belt-Mine has been eaten Spridgets 3
Gliderman8 Seat belt parkers anyone? Triumph 2
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
T Seat belt question.... MG 4
C Seat belt guide MG 0
J seat belt intallation in late BJ8 Austin Healey 24
Tinkerman TR2/3/3A Seat Belt Mounting TR 3A Triumph 6
tweety I need a Kangol seat belt Spridgets 1
T xj6 Seat Belt Jaguar 1
rlandrum TR2/3/3A TR3A Seat Belt Question Triumph 22
Indnrdr BT7 Seat Belt Mounting Acorn Nuts Austin Healey 0
mrv8q TR6 TR6 Seat belt mounting question Triumph 3
dklawson Spitfire Spitfire - Seat Belt Anchor Bolts [Size?] Triumph 6
milemarker60 Miata Seat Belt Receiver Question Triumph 4
X Seat Belt Holders MG 5
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
A Seat Belt replace MG 3
A Break Warning Light & Seat Belt Extenders MG 3
A MG in NASCAR / Seat belt clips? MG 10
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
W Seat belt warning electricals MG 0
T Seat Belt screw Rover / Land Rover 3
Monark192 Seat Belt Mounting Bolts MG 0
