RAC68
Hi Angus,
The additions you mentioned have been mentioned over time and taken by some. An oil cooler will assist, especially when combined with the use of a lighter viscosity oil then the commonly used 20w50. However, many who have installed an oil cooler have also mounted the unit behind a cut opening in the front lower shroud which means more permanent modification effort then just a mechanical addition … although, I expect it would not be difficult to find a way to mount the cooler radiator that does not require bodywork.
A thermostatic electric fan is also another solution that has been installed by a number of Healey owners. A fan is often mounted on the cross supports in front of the radiator and is quite effective when at idle at a light. However, since the common approach is to install a single large fan, when under way at speed, the fan acts as a block and is often required to keep running to maintain sufficient cooling. An alternative I have used in my TR7 is to mount 2 small AC cooling fans low (out of the direct air grill air stream) and on an upward angle toward the radiator for a more effective arrangement.
Also, such modifications as bonnet louvers, fender vents and fan shroud will also improve air flow and cooling through the engine compartment. One last thought is the creation of a behind grill shroud (not the standard air directing panels but a sealed shroud as used on the competition Healeys that direct all air passing through the grill directly to the radiator core. When at a stop light idle, this shroud will not allow the recirculation of hot radiator exhaust air by providing a sealed radiator intake.
Again, there are many ways to improve the cooling of a Healey but in most cases it would require the correction of a bad engine compartment airflow design.
Just my thoughts,
Ray(64BJ8P1)
Just my thoughts,
Ray(64BJ8P1)
