Spitfire Spitfire running hot
Spit_Newbie
Member
Hello all, Im having a hard time figuring out my very hot running Spitfire. Its running at about 240. Any suggestions? Ive been told they dont usually run hot. Help!!!! Spit Newbie
70herald
I think you have a 1500?? well bad news is they run hot if not set up properly.
1. is it really 240? (how did you measure this?)
2. do you have a full width radiator or the smaller one (there is a wide metal flange one side) the full width rad is much better.
3. is the radiator plugged up? Take it out and bring it to a rad shop to have it cleaned out / inspected. they will take it apart and can remove any crud or you may need a new radiator
4. thermostat? is it actually opening? unless it is new, put a new one in, they are cheap.
5. clean out as much crud from the block as possible. if you have a pressure washer, take off the pump housing and give the water passage a good spray.
6. clean out the block as best at possible. take out the drain plug and scrape around with bit of wire, rinse out, and you should get clean water.
7. are all the air deflectors in place? they make a big difference.
8. engine properly tuned? running lean will cause it to run hot. as will improper timing.
That should keep you busy for a while /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
vettedog72
I think 70herald has given good advise to resolve a hot Triumph, especially the part about cleaning out the rust crud in the block.
Dennis
My spit had started running hotter then normal, I pretty much did his checklist he has posted. (Good checklist!) My symptoms were, running hotter then normal and loss of power with poor idle. Turned out to be my water pump was starting to freeze up, no noise just an extra load on the engine.
Dennis
S
Spit_Newbie
Member
Thanks 70herold, I just finished running the flush. Quite a bit of rust particles came out. I used my garden hose to flush out the block until clean water came out. I dont have an actual petcock on the block. Which side of the block is the plug on? I would like to try to flush from that point too. The timing is a tad advanced but not to bad. as far as the radiater goes, its the smaller one. not a lot of crud came out when i cleaned it. The auto supply store was out of 180 thermostats so i got a 190, is that i big deal or will it work? Thanks for the help, Spit Newbie
G
If you have an automatic choke, I think it requires a 190 degree anyway to properly shut off. If I recall correctly, I think I read that in the Haynes repair manual.
Andrew Mace
Spit_Newbie said:
... I dont have an actual petcock on the block. Which side of the block is the plug on? I would like to try to flush from that point too....
Likely as not, your car will have only a brass hex-head plug in the block drain. It can be found on the RH side of the engine, towards the rear, maybe half-way down the block.
70herald
A 190 thermostat should be fine, that is not your problem.
Since you had lots of particles come out, you should have the radiator taken apart and "rodded" they will shove a rod down each tube and force all the crud out. Radiators make fantastic water filters.
TR3driver
Great Pumpkin - R.I.P
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Ask them about thermal efficiency while they have it. I fought overheating problems on my TR3A for a long time until I did that. They said the fins were no longer in good thermal contact with the tubes, so the radiator wasn't removing much heat even though the water flowed fine. After they recored it, all my overheating problems vanished.
foxtrapper
Amen to that! Many a "good" radiator in a hot running core has a lot of lose and missing fins.
Rodding often leaves a lot to be desired, as it leaves scum and scale on the tube walls, which act as insulators. Yes, it gets the chunks out, but it doesn't clean down the walls. So you can get water flow, but very little heat transfer to the tubes.
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
A Spitfire 78 spitfire running rich Triumph 5
A Spitfire Spitfire Running Rich Triumph 7
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
