running a little hot?
richardJr
I have a question for any caring soul that would like to offer up some advice. I have been working on a 71 gt that seems for the most part to be in great shape. Engine is strong and compression is decent with no adverse rocker noise. It is in origional condition...basically bought it as a basket case and saved it's life. The last fellow that owned it as one of my friends called it, "buggered it up good". The simple question I have is the "N" in the temp gauge. Seems I remember it running strait up on the "N" but now it is let's say about 5 oclock position. I did the best I could with cleaning the radiator and changed all the fluids...new cap and water pump is not leaking. Fan belt is within tollerance. Short of a new radiator which may or may not fix the problem...(if I even have one)I am some what at a loss as what to do next. I fear using any cleaners for I have heard they can cause more problems in the end with these old cars. All I can tell you is the water ran clean and not alot of crude came out as I put the old hose to the top and bottom. Was wondering if a bad temp sending unit would do this...you gonna laugh now...I am in fear of removing that too... gonna need a bigger boy to bust that nut off. Any advice would really be appreciated.
I wish upon you all and all loved one's a very happy day and a better evening to follow.
jsneddon
stick a meat thermometer in her and see if she's done....
calmone
possibly the fan clutch is defective, that will cause oveerheating. i've had the problem on two cars so far.
R
richardJr
Dear sir...
you got some smarts there... I never thought to actually check the darn temp via a candy therm or any other device that can aid me here. Simple things one forgets...bows head and laughs at self. I have read up on smiths guages and at times they are even a hit and miss. I really want to thank you for pointing out the obvious here and I shall now check to see where I am running at after the car is at running temp. Just for your info...I am running a 50\50 mix of anti freeze and water...going to put in a 160 stat...and see what happens. Maybe you could answer a simple question for me here...I have the timing set at 16 degrees btdc...(digital strobe)but have also read in other places 14 btdc is normal. I have also read these things like to have idle set at 600rpm+\- and timing as above mentioned 16 btdc. I have looked at the distributer for wear and no real slack to be noticed....(aka not lobed out and solid). Points and condenser are new along with all the htlead wires.New plugs..wires...coil... cap...you name it...any ideas why this thing won't run at any thing less then at best 900rpm?
any advice would be greatly appreciated. Fun little car you know...perfect for the weekend query and hair pulling moments. 1971mgbgt
Geo Hahn
[ QUOTE ]
So where do you point that thing Geo?
[/ QUOTE ]
Well, for this purpose I would point it at the tsat housing just to the rear of the thermostat (that's where the temp sender is). But if you're like me you'll be shooting temps all over the place... the head, exhaust manifold, lower radiator, glass of Coca Cola, back of your mouth, wife's ear, etc.
I used to think "the engine runs at 180 degrees" but you soon realize there is a vast array of temps under the bonnet -- some places are verrrry hot.
PS: I do not know the GT6 engine, but 600 rpm seems like a low idle -- is that what the manual specifies?
jsneddon
I love putting my brain around stuff like this... You aren't reading the water temp but the thermostat housing temp... but then again since the sending unit is attatched to the tstat housing it is acting as a bit of a heat sink anyway so it's a pretty valid test. But then again....
it makes my head spin.
So I take it that pointing it there seems to match pretty closely to what your temp guage says?
Since I'm not going to go out and spend 50 bucks on this very cool gizmo I have to ask:
How hot is your exhaust manifold?
And how hot IS your wife's ear ??? /ubbthreads/images/graemlins/smile.gif
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
D Rough running BT7 3 carb HELP Austin Healey 13
M TR5/TR250 problem getting engine running Triumph 15
D Nice to hear the old girl running again. Austin Healey 2
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
