Running Hot
roca
I have a 1980 TR-7 that was running as beyond the half way
mark and despite replacing the radiator, cap and thermostat it still can reach the 3/4 mark after 15 minutes. Needless to say, I am only testing it within 1 mile of my house. There isn't any noise or leakage from the pump. Should I replace the temp transmitter unit since it is a low cost item. Also, there is a wire with a connector that attaches to the res coolant tank. You will have to pardon my ignorance but what is the function of that component and could that be the problem? Any thoughts are most appreciated.
Rich
ObiRichKanobi
Here's a couple ideas...
First, are you still using the OEM viscous fan? If so, is it actually working?
Probably a doumb question, but all the hoses are good? If a hose is pinching off, if can slow the flow.
Are you really sure it's running that hot? If you can get access to one of those remote temperature "guns" shoot the thermostat housing and see what the temp really is. I know that the one time my car got that hot (during safety and emissions, when the bonnet was up) it was blowing antifreeae out the expansion tank.
The wire to the expamsion tank is for the coolant level sensor. If you have insufficient coolant, that's what will light up the light on the dash. Wouldn't have anything to do with running hot.
piman
Hello Rich,
what is the graduation at 3\4, because I would expect that to be a normal reading. As long it is not in a red band or more than 85 to 88 degrees (if you have a degree gauge) then that sounds OK.
Alec
R
roca
Thanks for your responses. It used to consistently read 1/2
or just below. The fan daes work. It did not appear to be overheating @ the 3/4 reading, however, I wouldn't risk driving it based on all I've read. I didn't see coolant
blowing out anywhere and levels appeared normal. Visually,
the hoses look okay. The bottom radiator hose does not have
a spring but looks okay(ie I don't notice any collapsing)
The temp rose gradually over about 15 min. Would this definitely rule out the temp transmitter? I don't have access to a temp gun. The radiator (used) was pressure tested before I bought it
Puzzled in Scarborough, Me
Rich Obi did you find out if the autozone in your area tests the ignition modules? /ubbthreads/images/graemlins/confused.gif
Deleted member 451
Check the easy stuff first. Put a thermometer in the radiator. I spent about 600 dollars to find out my gauge was incorrect.
ObiRichKanobi
Not exactly sure what the actual temp at 3/4 is, but am guessing that at the 1/2 mark it's around 180 degree F. The reason is that I've got a brand new 180 thermostat in mine, and you can tell by watching the gauge when it opens, and it opens just about right at the 1/2 way point.
Roca...Just started a new job and haven't had a chance to find out. Do want to tho...I think I have 3 of them laying around here and no use keeping any that are bad.
R
roca
Hello Bill,
So you would sick a thermometer in the expansion tank when
it reads 1/2 and expect about 180? If the temp rises over 15m on the guage would this rule out the temp sending unit? Also,
is there a way to check whether nthe lower rad hose is pinching while the car is running?
Thanks,
Rich
R
roca
I appreciate the offer but I'm all set. I was just passing the info along since it saved me $30 and I pulled it in 10 m
Rich
Deleted member 451
My tr3 doesn't have an expantion tank so I just stuck it in the radiator neck. You can buy a thermometer for about 50 dollars. I used my wife's candy thermometer and washed it off before she noticed it was missing.
I dont think I would open anything hot I let mine warm up without a cap on it.
T General Tech Running hot Triumph 8
sparkydave Trouble running hot Spridgets 10
Bob_Spidell Running hot/Overheating Austin Healey 44
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
I TR6 TR6 enine running hot - need some adivce Triumph 40
W running way too hot. Triumph 34
tinman58 TR2/3/3A TR3 running HOT Triumph 38
martx-5 TR2/3/3A TR3 Running Hot Triumph 15
T Running hot Triumph 7
VelodromeRacer Running engine hot...? Racing 6
bluemiata90 REBUILT ENGINE START-UP......RUNNING HOT Triumph 14
boeingpilot TR4/4A TR4A Is it really running that hot!?! Triumph 19
Ed_K If your car is running hot, get one of these ! Austin Healey 5
GT6_Mark Hot Running Problem – Twin Stromberg Triumph 16
S Spitfire Spitfire running hot Triumph 10
R Wedge TR8 running hot Triumph 11
jaybird B's running a tad hot MG 7
Stewart B's running very hot MG 21
R running a little hot? Other British Cars 7
gsalt57tr3 running hot Triumph 16
Steve P. MGB-GT Help:'70 MGB-GT running hot MG 4
Kim de B Running too hot up grades at speed MG 28
Mickey Richaud TR2/3/3A TR3 Running Hot Triumph 18
K TR2/3/3A What are the running symptoms........ Triumph 21
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
