Running engine hot...?
VelodromeRacer
Hey all.
I am chasing an issue with the motor. I added a speedwell Alum. radiator and have a 1275 engine with 1-1/2 Su carbs.
At Mid-Ohio, I could run only a few laps and she hit 210..and spiked even higher! We retarded the timing back to 28 degrees..The plugs on the rear carb are showing way to rich as well. We did a leak down test from 100 psi and it shows 5% loss for number 1 and 2% for 2-3 and 4. I need to do something as I am set to run at Road America in under 2 weeks and this is starting to get very troubling! I run a new Distributor from APT Fast with the Petronix and I have an oil cooler. The oil at Mid Ohio during the race at 5pm last Sunday hit 230 which it never gets to. Could it be a leak in the head that opens when it gets hot? Ideas? Kent Prather did help tune the car some at Mid-Ohio and we went from BG to number 6 needles for the carbs.
aeronca65t
Obviously, check the water pump belt. Even a tight one can slip if it's polished or old and hard.
Do you have a good ratio of coolant? Too much anti-freeze will make any car overheat (it doesn't reject heat as well as water).
Are you running a thermostat? I never do....just a blanking plate to add some restriction (and I make the blanking plate out of an old thermostat....just cut away the actual valve and mechanism.
Is your lower hose collapsing? The lower hose is under suction and will collapse if it becomes old. Many have a spring inside to prevent this. To check, warm up the engine and goose the gas pedal while obseving the lower hose.
Have you "burped" the coollant system to get all the air out?
Does your car have the little thermostat bypass hose? It's best to plug these off for racing (but it shouldn't make you overheat).
Sometimes the vanes on an old water pump will be worn down and corroded and won't pump enough.
You're not running an under-drive lower front pully...are you?
Pressure test the cooling system?
VelodromeRacer
VelodromeRacer
Nial,
Yes-good thoughts. More background. It is a new race motor so we went with a new water pump and I am running an oversized pulley as well. All hoses are new to. We did a pressure test of the radiator as well and had no leaks there. I have a blanking plate as well. Thinking it may be a head gasket leak? But it did pass the pressure test.
Scratching my head.....
aeronca65t
You have an oversized <span style="text-decoration: underline">water pump</span> pully?
That will slow it down and might cause overheating at slower speeds (but I sort of doubt it during racing speeds unless it's a LOT oversize.
Since the radiator is apparently the recent change, I guess you should look there first. It should feel hot evenly all the way across the front.
Maybe backflush it to see if there any stuff from the welding process still in it.
If nothing else, put the old rad back in?
And yeah, it could be a head gasket opening up when warm. Torque the head and see if any seem less tight.
Michael Oritt
Velo--
Sorry we did not get to meet at M-O.
The leakdown numbers seem okay but was the test done with the engine cold? If so, given that this may be a problem that only shows up at temp I would warm the engine to operating temps and then do it again. Also I think you would see some evidence of leakage or blow-by when you pull the cylinder head.
Please let us know.
VelodromeRacer
VelodromeRacer
Michael,
I am sorry about that as well-I was so tied up trying to tune the Bug that I didn't get much time to wander around! I ran with group 3-as SVRA penalizes Bugeyes that run the 1275 and they do not let me run with the square bodies or other Bugeyes. Sundays final race, I did move up and ran in the 1:54 range for my laps. That was better than the 2:03 I ran at first practice.
I agree that the leakdown needs to be done with a warm engine. That is what I hope to try on Monday.
Velo
pjsmetana
I used to run with no thermostat, a huge Aluminum Fluidine Radiator, 20%coolant 80%water, and a bottle of redline water wetter. At high RPM (7000-9000) I would actually drop temperature scary fast. Granted, this was on a Japanese B18C, but the idea should still hold true.
bluemiata90 REBUILT ENGINE START-UP......RUNNING HOT Triumph 14
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
vette Constant Engine Running RPM. Austin Healey 20
M TR5/TR250 problem getting engine running Triumph 15
TulsaFred Engine stopped running Spridgets 2
oxford engine running for the first time, but problem. Austin Healey 24
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
T TR4/4A Overdrive fade when engine is running warm Triumph 5
R low/high temp engine running question Spridgets 23
GeorgeB Engine running badley Spridgets 16
M New engine running like an old one.... MG 10
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
bighealeysource engine running weird on my BN6 Austin Healey 6
Ohiobugeye Got Engine Running, But have Hydraulic Leak Spridgets 2
beez TR6 Wanted Running TR6 Engine Triumph 0
R Engine kept running with the key out ? MG 17
C Key off, lights on engine still running??? Triumph 4
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
Mark Jones Engine missing/running poorly Triumph 10
E Turn signals and engine running on MG 5
beebopbogo Engine running really rough - 2 cyls? MG 8
Bruce Bowker engine keeps running Austin Healey 8
G Engine Barely Running - Need Help Triumph 14
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
