Restoring Plastic
mylesw
Hello
Quite a few of the plastic components (regulator, fuse box, fresh-air vent pipes etc) have overspray on them following a respray by the previous owner of my TR4. Does anyone know what the best way is to clean these items?
Thanks
Myles
T
Tinster
Myles,
A light touch with a single edge razor blade
and a tube of polycarbonate plastic, creme polish.
The poly creme is so gentle you can use it on prescription
eyewear. About $5.00 a tube.
d
trrdster2000
Hi Myles,
Rubbing compound works on lightly oversprayed bits and lacquer thinner works for heavy stuff, but you must be careful and not get it too wet, just get a rag damp, when you get finished cleaning use the compound to shine it up. Don't use a real heavy compound. If you are real good with a buff wheel and liquid car wax that also works great, but be sure and try it on junk first as it requires a slight touch not to melt the piece.
Wayne
Geo Hahn
You may even find something under the kitchen sink that will work and is pretty gentle... Soft Scrub, Bon Ami and Comet come to mind.
As suggested, test first on a hidden spot to see what results you get.
kodanja
Denatured alcohol works well without any damage to the plastic
angelfj1
be careful. some components are actually bakelite which is a linen based compound impregnated with phenol formaldehyde resin. it is organic and can be damaged by certain solvents. I have had good luck with WD40, very mild scotchbrite pads and elbow grease. dont use anything with an aggresive abrasive.
Brosky
You guys need to return to the bathroom. Crest toothpaste will do nicely and you don't have to be too aggressive.
And your parts will smell fresh and clean too!!!
T
Tinster
A little known fact: :yesnod:
The grit in many toothpastes and raw product for many 'scope lenses,
is finely ground, pure SiO2 quartzite from Huntingdon, PA quarries.
That's near Raystown dam, Paul!!
d :yesnod:
Brosky
Another little known fact, exposed here on the BCF....
What a country, ladies and gentlemen!!!
mrv8q
Brosky said:
Crest toothpaste will do nicely and you don't have to be too aggressive. And your parts will smell fresh and clean too!!!
I always save old toothbrushes, and use them in the garage to help clean parts, etc. I especially like the battery powered ones....
M
mylesw
Thanks for your suggestions. When does buy "polycarbonate plastic, creme polish" from? I was in my local hardware store the other day and all I could find was plexiglass cleaner.
Thanks
Myles
Basil Restoring plastic lens covers? Restoration & Tools 6
M MGA Restoring a plastic dynamics MGA hardtop MG 4
drooartz Restoring Penny the Bugeye Spridgets 22
Twit TR4/4A restoring TR4 sun visors Triumph 0
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
angelfj1 TR2/3/3A Restoring Smiths heaters as fitted to a 1959 Triumph TR-3A Triumph 4
K Restoring Horn Push Button Austin Healey 12
B MGB 79 MGB - restoring emissions controls MG 5
S Restoring a bj7 floor issues Austin Healey 3
pbraun Restoring that Moke British Motor Corp 10
K TR2/3/3A Restoring a tonneau cover? Triumph 3
tahoe healey restoring the windshield Restoration & Tools 7
Jim_Gruber Dye for Spridget Knobs - Restoring dash Spridgets 12
J Restoring a '62 TR3B Restoration & Tools 2
PatGalvin TR2/3/3A Restoring Chrome, on a budget... Triumph 19
C TR5/TR250 TR250 Worth restoring Triumph 18
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
A Restoring '53 Austin Somerset Other British Cars 9
M Restoring proper order to spark plug wires Triumph 36
Jim_Gruber Meeting a pair of 20 y.o.'s restoring a Spridget Spridgets 14
N BJ8 restoring carburetors Austin Healey 13
HealeyRick Restoring a Healey is Easy Austin Healey 7
S Spitfire Question on restoring a 73 spitfire Triumph 11
Y Restoring a 58 100 six front shroud Austin Healey 1
K TR2/3/3A Restoring a TR3A Grille? Triumph 12
M TR6 Restoring my TR6 [pics] Triumph 8
K Stuck float in Su fuel bowl.restoring carbs. Triumph 3
W restoring a BN2 - need advice on sheet metal Austin Healey 10
EinsteinsDad Restoring MG Frame Restoration & Tools 12
A Restoring headlights Restoration & Tools 3
B A area of interest when restoring. Restoration & Tools 2
B Restoring Triumph Triumph 3
V Restoring rostyles. Spridgets 6
T GT6 GT6 - no offense anyone, are they worth restoring Triumph 28
I Restoring brake, gas lines Spridgets 28
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
M Restoring Plated Items Triumph 2
M Restoring Switches Triumph 6
T TR4/4A Ideas on restoring the TR4/6 center dash supports Triumph 6
Tullamore MGC MGC GT: Worth restoring? MG 26
Z Restoring Bakelite - Hard rubber MG 15
Bruce_B Nice job of restoring an AH Sprite [with pictures] Spridgets 13
TRMark Restoring my old race car Other Cars 11
N Spitfire 75 Spitfire needs restoring Triumph 5
KVH Still Restoring the Underside Triumph 4
B Restoring a MK I Steering Wheel MG 8
P Restoring dashboard on BJ8 Austin Healey 5
tony barnhill MGB Restoring an MGB Works Hardtop MG 45
D MGB Hi, Restoring a 1964 MGB MG 18
