Replacement Rear View Mirror '70-79 style
Jim_Gruber
In the process of reinstalling another windshield on Bugsy my '68, and have discovered my rear view mirrow has a different mount. Rather than remove, and rerivet and do retrofitting, anyone got a rear view mirror from a 70-'79 Midget sitting around they want to sell. This is the type that secures to the windshield with two screws. VB Part 9-092? Thanks
thistle_3619@yahoo.com
If someone doesn't have a decent one for you, let me know I'm pretty sure I have a usable (but worn) one that I can mail to you.
Jim_Gruber
Jim_Gruber
Thanks Trevor,
I'll likely take you up on the offer. I don't need anything perfect just serviceable. Let me see by end of day who else responds. I'll let you know.
Did my good deed and payback of favors to next door neighbor this morning when I went over to enlist his help in reinstalling my windshield. Found him swearing in his garage trying to fabricate a brace for the front of his boat trailer. He had angle iron, drill press, files, clamps, and lots of frustration emanating from his garage. Grabbed my MIG, clamped up what he was trying to drill and tap and bolt and within 20 minutes I'd paid back about 3-4 years worth of borrowing his big ladder and asking him for an extra pair of hands every once in a while.
3 of 4 windshield bolts are now reinstalled other than the bas_ard on the top right behind the wiring harness. Now gotta go find a midget to get that one in there. Progress ever onward.
I went and checked. I have two of those mirrors. One has been painted and the edge of the glass has discoloration, the glass in the other looks better, but the plastic is a little powdery (would probably look OK with a little paint).
Usually at swap meets you can find boxes of those mirrors usually going from $5-15 depending on the condition and your haggling skills. :wink:
Jim_Gruber
Jim_Gruber
Trevor,
How much do you want for the one that needs paint and cleanup. I'll put a check in the mail. Send me your address. thistle_3619@yahoo.com I'll need before August when next local Dayton LBC Car Show is. I'd better get Bugsy back on the road and finished before then.
Mailing Address:
Jim Gruber
3656 Echo Hill Lane
Beavercreek, OH 45430
Thanks.
No charge, just refund me the shipping when you get it.
And remind me to put it in the mail on Monday.
Jim_Gruber
Jim_Gruber
Thanks Trevor,
As ever this list amazes me.
I put it in the mail today.
I used the Ugly Bug to run errands today (since the kids are at Grandma's house). It was going well until a sudden rubbing noise appeared from the left drum while going around a corner. I hope it is something simple. I chose a route home that didn't involve many turns and the rubbing only occurred during corners.
Jim_Gruber
Jim_Gruber
Thanks Trevor, I'll be on the lookout for it. Got some replacement bolts for center rod today when I was running erands so windshield reinstall will be complete tonight if I can find 20 minutes of garage time. Better half needs to quit buying stuff for me to plant and deciding she needs another flower bed expanded. My Ozark's money has all gone into plants for her.
Trevor it was probably the speed at which you went around the corner. I'm assuming LR Drum and that you've upgraded to discs on the front. Sure tire wasn't rubbing?
Nope, I think the drum was rubbing the backplate. I had already "eased" the edge to prevent rubbing. (This is needed with later model back brakes on early model rear end.) But... I forgot to put those locating screws into the drum. It shifted behind the wheel and was rubbing. I think I have it fixed.
Now... on to the next issue: I removed too many leafs from the rear spring and I'm bottoming out the suspension too easily. Putting a leaf back in each side is not a job I'm looking forward to.
JPSmit
diet? :devilgrin: do you have the front spacers? Are they unique to 1500's?
Nope, no spacers. Not much you can do to alter the ride height in the rear without changing springs or adding a wedge.
Oh... and diet is on my list of things to do. :wink:
G
My 79 mirror is nice however theres a small crack in the plastic. If you want it, PM me your address and I'll mail it to you.
jlaird
Ha, after the Loto wife said she gained two pounds. Me about the same but I need to loose more, more, more.
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
RAC68 Disk Replacement for Rear Drums Austin Healey 1
MGTF1250Dave TR2/3/3A Rear Apron Replacement Triumph 2
RJS TR4/4A Rear Brake Hose Replacement Triumph 7
MGTF1250Dave T-Series TF Gearbox Rear Seal Replacement MG 2
M TR2/3/3A Rear flasher lamp replacement Triumph 10
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
DornTRoriginal TR2/3/3A Rear Axle Bearing[s] repair vs. replacement Triumph 10
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
PHerder Rear rubber bump stops removal/replacement? Spridgets 1
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
D Rear wheel cylinder replacement question BT7 Austin Healey 6
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
GBRandy Wedge TR8 rear wheel bearing noise / replacement Triumph 5
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
Lin Rear Hub stud replacement Austin Healey 1
tosoutherncars rear panel replacement? Spridgets 10
MadRiver Rear spring removal/replacement MG 8
S Rear Suspension Springs Removal/Replacement Spridgets 2
mrv8q TR6 TR6 Rear gearbox mount replacement Triumph 9
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
R Rear shock replacement for the KYB conversion Triumph 8
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
J BJ8 rear boot floor replacement. Austin Healey 9
kindofblue TR5/TR250 Rear brake hoses replacement on TR250 [IRS] Triumph 6
RobSelina Rear quarter pannel replacement/conversion Spridgets 4
bobmga62 MGA rear tube shock replacement for MGA MG 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
