Rear Wheel Bearings
JJS
Member
Hi All,
I'm working on completing (starting?) a restoration of a 1960 BN7. I'm assembling the rear axle and hub and noticed that the bearings have a plastic ring or shield covering the ball bearings.
Is this a sealed bearing. It doesn't look like there is an easy way to get grease into the small space left uncovered by the plastic shields.
The bearings are NSK 4209BTNG, sourced from Victoria British.
Thanks
Joe
Keoke
Hi Joe, Originally the rear bearings were not shielded. However if they are shielded on the out board side only it will tend to reduce oil leakage from the seals. Lubrication for these bearings is provided by the oil in the differential and conventional greasing is not required. However, this is the first time I have heard of this.--Fwiw--Keoke
jjs, huh a plastic shield? perhaps your talking about the large "o" ring that sits inside the flange? perhaps you should check and see if you got a healey rear end in there at all? i for one happen to be visually stimulated "a typical trait for men" pictures help.--- keoke i cant wait till he starts talkin bout da tools fur dis job! will learn em. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
J
JJS
Member
Keoke, Thanks for the info. The plastic ring (shield) is on both sides of the bearing. There isn't an outboard side to the bearing, it looks identical on both sides except for the manufacturer's markings.
Based on your comments, I'm going to install the bearing and not worry about packing with grease.
Joe
steveg Shimmed rear wheel bearings Austin Healey 13
Tabcon Rear wheel bearings- GET OUT! Triumph 7
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
svtmikey GT6 Help on GT6 rear wheel bearings Triumph 3
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
C Spitfire rear wheel bearing Triumph 2
R TR6 Rear brake wheel cylinder fitment Triumph 5
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
Martinld123 My left rear wheel is locking up Austin Healey 16
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
R TR2/3/3A Rear wheel cylinders for 54 TR-2 Triumph 3
S TR2/3/3A Upholstering the rear wheel arc Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
D BT7 rear wheel leaking Austin Healey 25
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
T TR6 grinding right rear wheel Triumph 22
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
C Rear wheel bearing or other cause? Austin Healey 18
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
G rear wheel studs on my 1967 BJ8 Austin Healey 5
drooartz Rear wheel hub oil seal Spridgets 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
J TR4/4A TR4A rear wheel cylinder source Triumph 3
RickPA BJ8 rear wheel cylinder install Austin Healey 1
trotti Pulling off the rear wheel cylinder Austin Healey 11
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
R Bugeye rear wheel advice needed Spridgets 20
Mickey Richaud MGB Leak at Rt. Rear Wheel MG 6
G TR4/4A tr4a irs left rear wheel Triumph 14
Crankshaft TR2/3/3A Noise from rear wheel. Triumph 1
J TR6 Inverted righ rear wheel [need help] Triumph 10
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
TulsaFred What holds the rear wheel and axle on? Spridgets 6
B Rear Wheel Bearing Oil Seal Spridgets 7
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
T 76 midget rear wheel cylinder Spridgets 5
regularman What is the permanent fix for rear wheel seals Spridgets 14
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
dklawson Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO? Triumph 7
G XKE rear wheel bearing replacment Jaguar 4
