TR2/3/3A TR3 Rear Wheel Bearings
JFS
Bronze
Although I have repaired, replaced, or maintained just about every other moving part on my 58 TR3A over the last 25 years, I have never serviced the rear wheel bearings. After seeing a 3 break one at Rockford last summer, I think I should probably check em out, although the wheels turn smoothly and quietly. I have a good 3-jawed puller and think it should work for pulling the hubs. Is a special puller needed to pull the bearings? Will the end float have to be checked after bearing repacking/replacement? Any precautions I should be aware of?
Geo Hahn
Good luck -- sometimes the puller gets that hub apart, sometimes it seems nothing short of a nuclear warhead will separate them.
I would not use a 3-jawed puller if it is the kind that fastens under the studs -- it will surely bend the studs and hub before getting it separated. At least spring for a 4th jaw for equal pull -- it may not work but the risk of damage is less.
I have never pulled the bearing, just cleaned and re-packed in situ and replaced the 2 seals (one on bearing, the other in the diff body). A small puller and seal driver will be helpful for those.
Yes, you will need to reset the end float which may require an assortment of shims (as well as a dial indicator gauge, etc).
Personally (on a car not being raced): if they are not leaking and not making noise I would grease 'em thru the zerk and leave well enough alone.
trrdster2000
Well said George, surprising how many owners don't know that fitting is there, not only the 3's but 4's and solid axle 4A's if my memory serves me correctly. The one on the Roadster is on the outside in a little recess, much easier, just take off the hubcap.
Wayne
JFS
JFS
Bronze
Glad I posted! I didn't think of repacking them in situ nor did I know that all the 3's had grease zerks. I saw the zerks in my manuals but not on the car so I thought perhaps they discontinued the zerks after the manuals were printed. Geo, I'll take your advice and grease the zerks first (after I find them) since they're quiet and not leaking. I don't race, but I have autocrossed and driven it sportingly for 100,000 miles. Thanks, guys.
Alan_Myers
Hi,
Boy, do I agree with the other folks about not removing the rear hubs unless necessary!
This is not a fun job. Yours are most likely seriously affixed to the axles after all these years and would almost certainly require some major effort to remove. Even the special tool, which is hard to find and pricey, might not budge them. That means taking the axle/hub assembly to a machine shop, using a large press (probably 20 tons) on them to push the hub off, and hoping for good results.
In fact, it's all too common for hubs to get bent in this process, ruining them. It takes a lot of force to remove the hub from the end of the axle. So, avoid the job if at all possible.
Noisy bearings, or roughness when spinning the wheel, or any side play, would certainly indicate a problem. But I think the primary sign of a problem is grease/oil on the brake backing plate, leaking out of the hub, which will eventually get onto and ruin the brake shoes. This is due to the hub seal giving up, and I would guess is a more common problem than actual bad bearing, or at least an initial sign that the hubs need attention.
Yes, get in there and grease each hub with the zerks. I'd suggest not putting more than 5-6 pumps with the grease gun in each initially, to avoid over-filling, which might cause grease to ooze out past the old seals.
It might be possible to clean the hub bearings withoiut removing the hub from the axle, too, since the entire axle with the hub still mounted can be removed from the axle tube simply by removing the 6 bolts right behind the brake backing plate. With the hub and axle off the car, it would be pretty easy to wash out the bearings, let them dry and repack with new grease.
*But*, I wouldn't necessarily encourage doing this, either.
If the hub/axle assembly is removed, there are two more seals inside the ends of the axle tube that will very likely get damaged in the process and need replacement, too. Also, new locking washers will be needed for the six bolts per side. Plus there are shims used between the brake backing plate and end of the axle tube, to set the correct amount of axle end play and centralize the axles in the differential. If removing the axles, it helps to carefully count the shims and keep the two packs as separate sets for their respective sides, to reinstall exactly as they were removed. But, end play should still be checked (.004" if memory serves) and adjusted if excessive. Even giving the brake backing plates a fresh coat of paint can effect end play quite a bit.
So, all in all, I'd say don't tackle the job unless it's really necessary. Keep the hubs well lubed through the zerks, but not over-filled.
jsneddon
[ QUOTE ]
[/ QUOTE ]
Yup.. I didn't know about it either. I'll put this one on the top of my list of things to do this weekend.
Here's the location and description in the TR3 owner's manual:
Donald1107
Just contemplating this very same issue. About everything else mechanical is done on my 3. Now I won’t tackle this project unless something clues me in to its necessity.
Merlin63Tr4
CJD
Fortunately, bearings don't often fail without ample warning. You will start to hear (and feel) a dull rumble if the rear bearings are failing. It will be constant while the car is in motion, even with the engine turned off and rolling in neutral. I bet the failure you saw at Rockford was an axle. Axles give no warning at all. If you have the Girling rear end, though, axle failures are also rare. Not so with the Lockheeds.
DavidApp
There is a drawing for a tool to separate the hub from the axle using a couple of nuts and a bolt all sourced from Granger or McMaster-Carr. Some welding is needed to complete the tool.
David
mastaphixa
Bronze
I was able to use the above mentioned tool to remove my axles from the hubs with very little drama. I'd do it again in a heart beat.
Andy Blackley
Here is a link to the tool in question. I had one made last year and it worked a treat. My experience is at the end of that thread.
BarryO
Before you grease the real axles make sure to check that the drain hole isn't plugged with crap. I didn't know about this and when I greased
the axles i did too many pumps with the grease gun and it seeped out the passenger side hub seal and grease leaked onto the brake shoes, a hard stop really got my attention
I pulled out both my axles and had a Triumph mechanic put in the new hub seals for me since after reading up on it sounded like it might be difficult, you must have the right tools for this job. I did the rest of the work with new brakes shoes , all back together and float set and that's a job in itself. In the photo you can see the plugged hole at the 7 O'Cock position , make sure it cleaned out and follow the manual (5 pumps with the grease gun).
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
S TR2/3/3A rear brake lines tr3 Triumph 3
