TR2/3/3A TR3 Rear wheel brake cylinders
JPeter
Member
TR3 Rear brake questions.
My car will be a easy driver - no racing.
I have 10 inch drums with 2 1/4 inch wide shoes and the brake cylinders were 5/8 bore with slotted piston tops. Mine are hopelessly corroded and need to be replaced. It appears that the 5/8 bore is NLA.
Will the rear lock up too easily if I go to the 3/4 bore cylinders? Or do I have no choice? Is my only option to find a balance valve? Who is the best source for the new cylinders?
Also - The brake shoes were ruined by grease from the hub. I have the axle assemblies all taken apart to replace the seals and bearings. Who is the best source for new shoes?
As always I look forward to any advice or ideas and experiences that any of you have. Thanks
Bugeye58
You can have your existing wheel cylinders overbored and fitted with either brass or stainless steel inserts in the original 5/8" diameter.
White Post Restorations does a good job of this.
You could also contact Peter at:
https://www.nosimport.com/
He may have some good ideas.
I would imagine just about any of the normal vendors can supply quality shoes.
Jeff
Don Elliott
I had my 10" rear brake linings re-done in 1990 when I was finishing my restoration. They were bonded onto the original shoes by a local clutch and brake service shop. They have done fine for the 17 years since then and 94,000 miles.
Don Elliott, 1958 TR3A
Harry_Ward
Andrew Mace said:
10" shoes are scarce and expensive, last I knew. But they can be relined by anyone who does such work. You might contact Ted Schumacher, who can reline them with Kevlar linings.
Andy's right!!! Be very careful who you send or give your shoes to. One of the first mistakes I made was to assume they were easily available. I had original shoes with the original striping which I gave to a local vendor as a core. I could have cleaned them up but they were covered in oil and brake fluid and I though this would be for the best. Was I wrong! The guy said no problem come back in a week and I'll have them... Well six months later he gave me some shoes back which didn't even look close to the ones I gave him. They did fit and I do still use them but they look like they came out of a Toyota. Moss lists the 10 inch rear shoes but they are $$$ expensive.
Any size cylinder can be used to replace the 5/8ths original as long as they are replaced as a pair . Mine had 3/4 as a replacement to the original but I replaced them back to the 5/8ths.
YankeeTR
Also see Apple Hydraulics and Joe Curto in New York for cylinder resleeving.
Many shops that reline class 8 truck brakes can do you 10" shoes...Praefke Brake in Milwaukee has done mine in the past.
Banjo
The shop I was working at whae I did TS816 ordered the 10" shoes from Moss. They were NOS. The final inspecton date on the box was 1958, they were packed in the wax paper, and looked like a lumpy fiber or rope bonded to the backing plates.
You're probably far better off having a good brake relining shop do your set.
I'm still on the fence of what I'm doing on TS5012. I'd like to keep it original, but I have most of the stuff to do a complete brake upgrade, so I may wind up with a later TR3 axle.
Thanks guys for the links on wheel cyl re-sleevers. I need to get the Jag done.
Platinum
Over the years we've had some fairly exotic shoes relined at a local truck brake/clutch house. All were done correctly and at great pricing compared to hunting down crossover bits to order. Case in point: mid-fifties Nasty Martin DB2/4 drophead. Shoes at all four corners and made of Unobtainium. IIRC, $100 did the deed.
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
S TR2/3/3A rear brake lines tr3 Triumph 3
