Rear shocks
v8mgbal
Hello all, I have two different rear lever arm shocks on the rear end. one has an almost straight arm the other one a more z angled arm. which is correct for a 74 midget thanks.
jhorton3
If memory serves me correct I believe I have straight arm shocks. I'll double-check this evening when back home.
v8mgbal
v8mgbal
Odd huh, I looked in the catalogs and there are two different # for shocks. one for 58 to 64 and the other 64 to 79 just not sure if it is a big deal or not. thanks for checking guys. Alan
v8mgbal
v8mgbal
Hey, I think I figured it out. it might be an MGB shock instead after looking at the pictures in the moss catalog, but I didn't think they were the same size.do y'all think that's possible.
PeterC
Alan, An MGB shock body is too big to fit the Spridget mounting holes.
Without going into a lot of detail, there are only 2 different mounting flange configurations for the rear 2 bolt shocks. Small, like Sprite, early TRs, early big Healeys, Minors, Morgans. Big, like Bs, Cs, As, 65 on big Healeys, 65 on TRs, Saab 95 (yes, Saab)
If you can see the number that is stamped on the lower edge of one of the mounting ears, that will tell. If the arm is bent Z like, I would suspect 6076 (big Healey early) or TR2,3,4 with 6058 or 7999.... but it's just a guess;-)
Finally getting my crashed computer up to speed.
Peter C
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
T TR2/3/3A TR-3a Rear Shocks Triumph 1
T TR2/3/3A Rear shocks and rattle Triumph 5
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
mgedit TR2/3/3A Rear Shocks Loose Triumph 16
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
T TR6 TR6 aftermarket rear shocks Triumph 35
Keith_M Rear Shocks Spridgets 5
Boggsy64 MGB Rear Rebound straps and shocks MG 5
1 TR6 oil for rear shocks Triumph 5
S Clunking from rear shocks ...? Austin Healey 15
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Gerard Spax rear shocks on Bugeye Spridgets 12
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
D MK2 rear shocks Jaguar 3
K TR2/3/3A TR3A: Refilling rear shocks? Triumph 4
S 91 XJ6 rear shocks needed Jaguar 3
I TR6 What type of oil for TR6 rear shocks? Triumph 2
Tronch Rear shocks and anti roll bar Austin Healey 4
AUSMHLY After market rear tube shocks Austin Healey 28
davester MGB MGB rear tube shocks...which ones? MG 18
Sprocket rear shocks for a xj40/ Jaguar 3
C Rear Shocks Triumph 17
tahoe healey rear shocks again Austin Healey 16
R Koni Rear shocks, setting? Triumph 2
mgbmedic MGB rear tube shocks for MGB MG 20
R TR6 TR6 rear ride height with tube shocks Triumph 5
MadRiver Rear Shocks Triumph 19
P 2 questions Alternator conversion and rear shocks Triumph 4
Wana Installing new rear shocks Austin Healey 8
T tr4-rear tube shocks Racing 2
George Zeck 1/4 ellipticals & Rear Shocks .... Spridgets 11
T Filling rear Bugeye shocks - any tips? Spridgets 7
bluemiata90 Leaking rear shocks Triumph 11
jaybird Rear shocks MG 21
R TR6 '74 TR6 Rear Shocks Triumph 18
Hegg Elan +2 rear shocks Lotus 4
C MGB MGB Rear Shocks MG 5
S Rear Shocks Austin Healey 2
Basil Rear Shocks installed Jaguar 9
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
