MK2 rear shocks
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
So, um, how long do original Girling shocks last?
By lasting, I mean no leaks, even, hard pull in both directions when out of the car.
By original, I mean probably, with the undercoating on one side of said shocks only.
99,890 on the clock.
Dave
Exotexs
Girling made great shocks in my opinion, too bad they went out of business.
My '84 XJ-6 still has the 4 rear factory Girlings. I replaced the fronts with Boge around 1995 and they were a dissapointment from day 1. Never again.
Might as well use Monroe or Gabriel or Sears shocks and end up with a better shock, closer to a Girling. (being a pack rat, I kept the old front Girlings and still have them).
Ex
LarryK
As long as the car doesn't bounce when pushed down, the shocks are OK. No leaks helps. I replaced my MK 1 shocks after 40 years because they were rusted from sitting in a field and were quite bouncy. Now it has been sitting for 10 with a new set of Koni's.
Platinum
mehheh. That reminds me, Larry... I gotta go remove a set of Koni's wot've been sittin' in the Upscale Yard Art for a <span style="font-style: italic">while</span> now... The Spider needs 'em.
D MK2 rear springs Jaguar 3
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
D MK2 rear axle "Bump Steer" Jaguar 4
E Rear Brakes for MK2 -1960 Jaguar 3
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
H MK2 lover, but... what about an E type? Jaguar 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
T Spitfire MK2 Generator Triumph 3
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
T Spitfire 67 MK2 Wiring Triumph 12
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T MK2 vs 420 values Jaguar 20
A Austin Cambridge MK2 Other British Cars 2
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
I 1961&62 Mk2 sprite roofs Spridgets 1
I 61&62 mk2 roofs Austin Healey 2
D MK2 fuel system Jaguar 1
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
LarryK Found MK2 parts in cavern. Jaguar 3
blurooster MK2 for wife Jaguar 21
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
D MK2 front motor mounts Jaguar 0
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
Sopwith_Camel mk2 parts left over Jaguar 4
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
H MK2 Brake problems Jaguar 2
Lin Check Valve for Reservac Tank - MK2 Jaguar 3
M Spitfire Spitfire MK2 calipers Triumph 4
B going to look at a 61 mk2 Jaguar 5
AN5Sprite Jag Mk2..Deal or No Deal? Jaguar 12
D MK2 brake puzzlement Jaguar 15
C What are the differences in Midget MK2 and MK3 top Spridgets 6
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
longbridgehealey top bow mk 1 and mk2 sprite Spridgets 4
6 '65 MK2...typical "whats it worth ? " post Jaguar 4
J Brakes for a Mk2 Ford Cortina Other British Cars 4
D MK2 idler arm Jaguar 6
K Door Strikers and Latches MK2 Triumph 3
D MK2 upper radiator hose question Jaguar 3
D MK2 wiper motor Jaguar 4
D MK2 sandwich mounts Jaguar 3
