MK2 idler arm
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
My MK2 has a cap on top with a small vent hole, similar (but
smaller than) those on the wheel bearings.
My J.33 parts manual shows a tower with a grease fitting.
When did they change idler assemblies, is mine older or newer than 1964, or is there a top piece that fints on in place of the cap to allow regular greasing?
Thanks.
Dave
Platinum
Don't think I ever saw one without a grease fitting.
Deleted member 8987
Well, if my wife didn't have my camera, I'd post a picture. Puzzled, I yam.
Platinum
Understood!
Any evidence there WAS a fitting in the hole?
Deleted member 8987
No...the cover is stamped light steel, looks just like the dust covers that fit over the spindle nut on the front wheel hubs, just smaller.
Keoke
MY 250 V8 should be the same as MK11's what year is your MK??
Up scale of course :laugh: but it has a small 1/4" plug that is removable for refilling with oil;
Deleted member 8987
64. You know the dust caps over the outer wheel bearings in the front wheels, with the vent hole in the centre for when you use the grease fitting?
Same cap,just a tad smaller OD. Pull it off the same way you pull the hub dust caps off. My idler assembly has roller brearings, not bushings. I am guseeing it's an upgrade somewhere along the car's life.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
H MK2 lover, but... what about an E type? Jaguar 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
T Spitfire MK2 Generator Triumph 3
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
T Spitfire 67 MK2 Wiring Triumph 12
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T MK2 vs 420 values Jaguar 20
A Austin Cambridge MK2 Other British Cars 2
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
I 1961&62 Mk2 sprite roofs Spridgets 1
I 61&62 mk2 roofs Austin Healey 2
D MK2 fuel system Jaguar 1
D MK2 rear springs Jaguar 3
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
LarryK Found MK2 parts in cavern. Jaguar 3
blurooster MK2 for wife Jaguar 21
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
D MK2 front motor mounts Jaguar 0
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
Sopwith_Camel mk2 parts left over Jaguar 4
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
H MK2 Brake problems Jaguar 2
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
Lin Check Valve for Reservac Tank - MK2 Jaguar 3
M Spitfire Spitfire MK2 calipers Triumph 4
B going to look at a 61 mk2 Jaguar 5
AN5Sprite Jag Mk2..Deal or No Deal? Jaguar 12
D MK2 brake puzzlement Jaguar 15
C What are the differences in Midget MK2 and MK3 top Spridgets 6
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
longbridgehealey top bow mk 1 and mk2 sprite Spridgets 4
6 '65 MK2...typical "whats it worth ? " post Jaguar 4
J Brakes for a Mk2 Ford Cortina Other British Cars 4
K Door Strikers and Latches MK2 Triumph 3
D MK2 rear axle "Bump Steer" Jaguar 4
D MK2 upper radiator hose question Jaguar 3
D MK2 wiper motor Jaguar 4
D MK2 sandwich mounts Jaguar 3
D MK2 console armrest Jaguar 3
D MK2 rear shocks Jaguar 3
