Clunking from rear shocks ...?
SteveHall64Healey
My rear shocks are making a clunking sound. This is happening upon launch and in the first few milliseconds of braking. I've checked the rear brake cylinders and they are staying firmly in place. Do my shocks require a rebuild or flush and fill periodically. I am fairly certain that tje previous owner did not maintain them.
Thanks
Steve
oakville, ontario
oxford
Hi Steve
I could be on the wrong track but my MGA was doing the same. It turned out to be worn hub splines: a clunk on braking and lift off. Might be worth checking if you haven't already replaced them.
Cheers
Matthew
Patrick67BJ8
Thanks
Steve
oakville, ontario
Before you tighten up the shock bolts check to see if you have movement that would indicate the holes in the frame mount have gotten "oval". Same for the shocks. I had this problem with one shock mount on the rear.
RDKeysor
Bronze
I also traced a clunking in the rear of my BN7 to the two bolts that attach the left rear shock to the frame. Both loose. The right side was snug, however.
bob hughes
If the splines are worn, try tightening up the wheel spinners a tad to prevent movement - just to see if it reduces/removes the problem. I know my front splines are worn and I get a clunk on braking, wacking up the spinners helps, they are down for replacement in the fullness of time along with new wheels. The shock bolts are also prime suspects as previously stated - best of luck
:cheers:
Bob
steveg
The shock mounting bolts need to be very tight. If shock is indeed loose or holes are oval, suggest replacing mounting bolts with grade 8 bolts and tall nuts with medium-strength threadlocker - to be able to tighten extra tight.
Flange locknuts would probably also work well. See:
https://www.fastenermart.com/html/encycnuts.html
Patrick67BJ8
It also was my left rear shock. Common problem to this particular shock?
I use hardened/Grade 8 flatwashers under the bolt heads. This increases the clamping area and hence the total clamping force of the (Grade 8) bolts. Also, I'm a big fan of threadlocker but it didn't work for me in this application (possibly because the bolt can turn). I use split lockwashers.
CanberraBJ8
Must be something about rear left shock! Mine also was leaking and moving.... Perhaps the leaking is what started the loosening of the bolts?
I have just fitted telescopics - a few more weeks of trimming and fitting seat belts etc, and then I can try them out! :driving:
steveg
Thanks for the advice everyone. The shocks are very tightly bolted the frame. Does anyone know if there is a mtce procedure for them?
thanks
steve
Am a little confused. The shocks have been bolted solidly all along and still clunk? Are you sure it's the shocks? Maybe I'm misunderstanding...
S
SteveHall64Healey
No, I am not certain that the clunking sound is due to the shocks. To rule out the shocks as the source of the noise, I checked for tightness as recommended by the various posters, and I would now like to perform the maintenance procedure on the shocks -if there is such a procedure. As mentioned previously, I doubt that mtce on the shocks was ever performed by the previous owner, and if there is such a procedure, my shocks would therefore be due for it. Does anyone know if there is one? I had imagined that this might include fluid changeout (and how to do that) as well as changing parts know to wear out....
steve
Keith_M
I am not aware of any maintenance (short of a complete rebuild) other than topping them up with oil occasionally.
Keith
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
P TR6 Clunking noise in rear continuing Triumph 39
P TR6 Clunking in rear [continued] Triumph 6
P TR6 Clunking in rear Triumph 14
P TR6 Clunking noise in rear Triumph 2
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
tr6web Clunking noise in rear Triumph 2
P TR6 Easier starting and clunking noises Triumph 11
P Strange clunking noise Triumph 20
MadRiver New Clunking Noise from the Passenger Side Triumph 2
T Clunking sound on shift. Triumph 15
SilentUnicorn Differential Clunking Spridgets 25
jerrybny Clunking Sound from differential Triumph 10
M front end clunking Triumph 9
Webb Sledge TR6 Clunking? [72 TR6] Triumph 12
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
