TR6 Clunking noise in rear
pdplot
I may have previously posted about the clunking noise ever since I installed a Goodparts spacer to even off the spring. I had another TR6 owner bounce the rear up and down and he thought it was a cracked frame due to the Roadster Factory tube shock conversion. I did have the frame welded near the differential mount when I bought this car 20 years ago. Is this a common problem? Is it easily fixed? Should I go back to the lever shocks? Is it dangerous to drive?
M_Pied_Lourd
Could be a number of things that need inspecting. I had the tube shock conversion on mine and had a break where the frame crossmember diff carrier met the chassis rail. Could be a diff mount, could be a loose shock, could be a bad u joint,could be something bouncing around in the trunk, could be a bad hub....so many things to check. Personally, I wouldn't want to drive mine before I found the cause of the clunk....
Cheers
Tush
KVH
The loudest most annoying clunking in my TR was resolved for the most part by one simple fix suggested by someone here, one of the genius types. He told me to wrap the brake likes in the same hardware store foam that's used for outdoor pipes. That way, those lines are no longer smacking the underside of the car as I hurtle over the many asphalt cracks and other imperfections in the roads of my near bankrupt community that won't fix them with any of the tax dollars we pay because they've found all kinds of ways to prove the old maxim true.
P TR6 Clunking noise in rear continuing Triumph 39
tr6web Clunking noise in rear Triumph 2
P Strange clunking noise Triumph 20
MadRiver New Clunking Noise from the Passenger Side Triumph 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
P TR6 Clunking in rear [continued] Triumph 6
P TR6 Clunking in rear Triumph 14
P TR6 Easier starting and clunking noises Triumph 11
S Clunking from rear shocks ...? Austin Healey 15
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
T Clunking sound on shift. Triumph 15
SilentUnicorn Differential Clunking Spridgets 25
jerrybny Clunking Sound from differential Triumph 10
M front end clunking Triumph 9
Webb Sledge TR6 Clunking? [72 TR6] Triumph 12
A Why is my car making this noise? Other Cars 5
Popeye TR4/4A Transmission noise - intermittent Triumph 22
AUSMHLY Transmission Noise Austin Healey 11
Gliderman8 TR6 Lever shock noise Triumph 18
LAW75 High-Pitched Noise Austin Healey 13
B High-Torque Starter Rattling Noise Austin Healey 3
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
S TR2/3/3A Noise from clutch area? Triumph 20
P TR6 Clutch pedal click noise Triumph 2
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clutch pedal noise Triumph 2
R Clutch Throwout Bearing Noise? Austin Healey 2
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
F TR2/3/3A Strange Loud Noise Triumph 11
Michael Oritt Clutch-related noise Austin Healey 14
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
G Tappet Noise Austin Healey 8
TulsaFred Generator or water pump noise? Spridgets 20
S Disconcerting engine noise, please help if you can. Austin Healey 56
2billydavies TR2/3/3A rattling noise on TR3a Triumph 12
J MGB Project car done; front end clunk noise while braking MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
RAC68 Loud Trans Scrapping Noise Austin Healey 9
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
K TR2/3/3A Gearbox noise.... Triumph 8
