Clunking noise in rear
tr6web
I have clunking noise in the rear that only happens when the car starts from cold and I back it out of the garage. I'm new to this stuff so any advice would be great. Thanks.
waltesefalcon
I agree with Jeff. If it is only clunking when the car is cold, try greasing your u-joints.
P TR6 Clunking noise in rear continuing Triumph 39
P TR6 Clunking noise in rear Triumph 2
P Strange clunking noise Triumph 20
MadRiver New Clunking Noise from the Passenger Side Triumph 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
P TR6 Clunking in rear [continued] Triumph 6
P TR6 Clunking in rear Triumph 14
P TR6 Easier starting and clunking noises Triumph 11
S Clunking from rear shocks ...? Austin Healey 15
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
T Clunking sound on shift. Triumph 15
SilentUnicorn Differential Clunking Spridgets 25
jerrybny Clunking Sound from differential Triumph 10
M front end clunking Triumph 9
Webb Sledge TR6 Clunking? [72 TR6] Triumph 12
A Why is my car making this noise? Other Cars 5
Popeye TR4/4A Transmission noise - intermittent Triumph 22
AUSMHLY Transmission Noise Austin Healey 11
Gliderman8 TR6 Lever shock noise Triumph 18
LAW75 High-Pitched Noise Austin Healey 13
B High-Torque Starter Rattling Noise Austin Healey 3
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
S TR2/3/3A Noise from clutch area? Triumph 20
P TR6 Clutch pedal click noise Triumph 2
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clutch pedal noise Triumph 2
R Clutch Throwout Bearing Noise? Austin Healey 2
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
F TR2/3/3A Strange Loud Noise Triumph 11
Michael Oritt Clutch-related noise Austin Healey 14
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
G Tappet Noise Austin Healey 8
TulsaFred Generator or water pump noise? Spridgets 20
S Disconcerting engine noise, please help if you can. Austin Healey 56
2billydavies TR2/3/3A rattling noise on TR3a Triumph 12
J MGB Project car done; front end clunk noise while braking MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
RAC68 Loud Trans Scrapping Noise Austin Healey 9
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
K TR2/3/3A Gearbox noise.... Triumph 8
