TR2/3/3A Engine noise
Kleykamp
OK, I'm going to be one of those guys that ask you to diagnose an engine noise without hearing it. Actually, just maybe point me in a direction of what I might check. The noise is not present on start up and does not show up until the engine is warmed up after driving a while. It sounds like valve ticking, but since valves are adjusted cold, I would think that they would become tighter when hot... not looser. I've tried a stethoscope around the head, water pump, block, fuel pump etc and don't pick up any unusual sounds. It seems to be at idle and not when under load. It does increase speed with increased idle. The engine runs fine with good power. It's a '61 TR3 that had a '58 or so engine in it when I got it. I discovered a cracked block and it seemed the easiest fix was a good short block so it now has a late ('67 ) or so block but ALL the other parts came off the running '58 engine, essentially converting it to look exactly like the TR3 engine.( open breather road tube etc.) Everything was inspected at assembly and appeared good. It has been running with the current drivetrain for at least 3 years, and I think the noise has been around all if not most of that time.(probably less than 500 miles, I don't drive it often and mostly short distances.) Part of me says "It runs good, drive it" but the Henney Penny side says it's a ticking time bomb of some catastrophic failure about to happen. Any suggestions. Thanks, Joe
Geo Hahn
Mine ticks. If the ticking were to lessen I would be checking the valve clearances.
What you describe may be normal - but impossible to say w/o hearing it.
sp53
If it is a tick could be a lot of things. With these engines I am prone to valve noise coming from a worn out rocker shaft if you hear a tick. You could reset the valves a little tighter for a short time and see what that does. I had a rebuilt engine that ticked and I thought I went through everything and it turned out to be a lifter. I checked them by tightening them up one at a time. My hotrod buddy said tighten it to .006 and leave it-- I did, the noise went away and did not hurt anything. I usually only genuinely worry when the noise has a deep thud. The rest of the stuff, I let go of as normal, or find it after time or if it gets worse.
Geo Hahn
...My hotrod buddy said tighten it to .006 and leave it-- I did, the noise went away and did not hurt anything...
I hope that works out for you. I set my exhaust valves to .012 (which may be why mine ticks) as I'd rather have a bit of noise than a greater risk of damage.
Roys
Member
Someone here said their noise was a bad spark plug wire arcing . After I saw that ,I went out & measured my wires(TR4 engine with a sometimes loud valve noise so I thought) . One Raja end was open ,probably arcing inside . Replaced it & now just have the usual valve noise (a loose valve is a happy valve ) .
nicko Strange Engine Noise Austin Healey 7
S Disconcerting engine noise, please help if you can. Austin Healey 56
P MGB MGB overheating with a squealing noise from the engine MG 11
Lutz Kramer Noise from the engine compartment Austin Healey 21
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
KVH TR4/4A Engine Noise--Advice Please Triumph 39
P Engine noise ~ Garbage disposer sound Triumph 9
bighealeysource Whirling noise from engine compartment in BN2 Austin Healey 3
V TR2/3/3A TR3 Engine Noise Triumph 33
mrsprite Engine noise help Spridgets 47
Stewart I think I'm going to be sick ....engine noise exp MG 9
RedTR3 Engine noise - towed home - what could it be? Triumph 44
6 noise from bottom of engine... Triumph 10
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A TR4/4A TR4 Engine noise Triumph 9
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
JPSmit very scary engine noise Spridgets 37
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
PeterK TR2/3/3A Engine noise in TR3A Triumph 2
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
G Strange Engine Noise...? Austin Healey 20
Monark192 MGB-GT Engine noise question - 67 BGT MG 8
R6MGS MGA MGA Engine noise??? maybe? MG 11
G Engine Noise--New Theory Triumph 26
sparkydave Bad engine noise? Spridgets 5
G Early 2.6 strange engine noise... Austin Healey 3
S engine noise Spridgets 8
vping Engine Noise - Video 1 & Video 2 added MG 59
J Engine Noise Spridgets 9
G Shrill noise after engine gets warmed up.... Triumph 14
8 1500 ENGINE NOISE Triumph 6
RobSelina engine noise, very worried.... Spridgets 11
S Engine noise MG 2
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
