Loud Trans Scrapping Noise
RAC68
A few days ago, a old (my age) 67 BJ8 owner (since ’72) gave me a call for some advice on the transmission of his car.After a short run, it was obvious that a metal scrapping sound was coming from in, or around, the transmission but all gears shifts were smooth and precise. Additionally, the O/D performed flawlessly and, when in O/D, the scrapping noise seemed to disappear and the trans/OD would substantially quiet down.
I would appreciate any ideas and/or suggestions.
RAC68 (64BJ8P1)
Keoke
WOW !!
Sounds more like clutch to me???
RAC68
RAC68
Rich/Keoke,
Thanks for the responses. Rich, something I had no thought of and very intriguing. The interesting thing about your thought is that his parking brake is also inoperable and he has had the rear hub seals and brakes recently replaced. Although, I too, was incline to have thought in the area of the clutch, as Keoke favored, I could not reconcile the fact that the scrapping sound significantly diminishes after O/D actuation? Also, if in the clutch or transmission, I would have expected some shifting difficulty or clutch actuation issues.
I had addressed some time next week to investigate getting his hand brake working and would appreciate any further thoughts.
Again thanks,
Ray (64BJ8P1)
kozelding
Check that the emergency brake cable is not rubbing on the drive shaft.
Rich
57BN4
I'll second this. I once hit a bump that manged to get the cable wedged between the driveshaft and frame. Scary noise that would change significantly with driveline torque load.
MikeP
Consider putting the rear up in the air too where the car can be run at idle and in gear and someone can walk around, peer underneath and localize where the sound is coming from. And even perhaps see what is doing it.
RAC68
RAC68
Thanks for your thoughts and replies.
Agree and would always like to know what I am addressing before delving into the pursuit and correction. However, in this situation, I have an emergency that is inoperable so intend to pull the passenger seat, console, and transmission cover address what why it is not working in the first place. While the cover is off, I intend to fuse the solenoid and will follow Mike's suggestion to make sure the issue was addressed and resolved before replacing all. Since my friend is away at the moment, I expect to address this issue some time the end of the week and report back. I have owned my Healey for since new and found that there is no such thing as a 5 minute job, so who knows what will be found.
Thanks again,
Ray (64BJ8P1)
Thanks again,
Ray (64BJ8P1)
I haven't had mine as long as you, only getting it in 1978, but I agree, and have long said that there's no five (5) minute job that can be done in less than half an hour!
We're definitely on the same page there! Good luck and hope it all works out in the end.
Oh, and I have to admit I was a little concerned when reading your second (2nd) sentence: "I have an emergency that is inoperable..." Glad you were only talking about the car!!
Keoke
OK Ray Just:
Make sure the fuse is readily accessible, is a slow blow type and does not exceed 10 Amps.
J TR4/4A Exhaust a tad too loud... Triumph 6
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
J MGB 73 getting loud squeal with acceleration MG 11
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Jim_Gruber In need of a really loud horn Spridgets 13
TEM666666 Exhaust loud popping: Lean? Rich? Fuel? What else? Spridgets 25
F TR2/3/3A Strange Loud Noise Triumph 11
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
AH67 loud enguine- valve like Austin Healey 18
AngliaGT Tossing Out Old Issues of Sports Car/The Wheel/Loud Pedal Racing 1
7 General TR way to loud in-take noise Triumph 4
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
jlaird Well for crying out loud Spridgets 4
jlaird Thinking out loud, comment pls Spridgets 6
RickB 1.5 M test drive really had me laughing out loud!! Spridgets 14
Stewart Thats one loud powered wheelchair MG 0
tony barnhill 18V Engine Issue [Thinking Out Loud] MG 17
B New fuel pump - loud ticking, now fuel spraying! Austin Healey 33
milemarker60 Spitfire Spit MK-IV Loud Pedal Assy Needed for Project Triumph 4
G LOUD Vibration at about 3000 rpms MG 31
M Loud Exhausts Spridgets 8
A Miss in engine and loud lifter[?] MG 3
J Loud flapping noise from center air vent Jaguar 2
S TR6 TR6 front brakes make loud noise Triumph 8
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
T General TR Another trans popping out of 2nd Triumph 14
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
AngliaGT Pontiac Trans Sport / Honda Insight Spotted 1
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
skystryd Trans and Diff Spridgets 7
G Trans Axle Parts Lotus 20
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
R General Tech Preserve eng/trans that has been removed Triumph 11
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
doc50 Nash Metroplitan trans swap? Other British Cars 33
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
S Smitty trans Master cylinder Austin Healey 21
C General MG Midget trans mounts MG 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
