Loud flapping noise from center air vent
JohnPal
1992 Vanden Plas. With the AC on, there is a loud, rapid, flapping noise that seems to be coming from the center AC vent. If I turn the temperature dial all the way to heat, the noise goes away. When the engine is under acceleration, producing torque, the noise goes away. Just revving up the engine in neutral has no effect, however.
I disconnected the vacuum line at the point where it enters the console beneath the battery and the noise disappears.
All this seems to indicate a defective vacuum actuator somewhere under the dash. It's interesting why the noise goes away while the car is accelerating in drive, but not while the engine is being revved up in neutral.
Any tips or suggestions on how to go about getting this fixed greatly appreciated.
Best regards.
John. /ubbthreads/images/graemlins/england.gif
Dave Russell
Yoda - R.I.P
John,
Sorry I can't help much. If the flap actuator is powered from engine vacuum, there is much less vacuum available when accelerating than when in neutral. The "flapper" may be spring returned to the heat side so when it is in the cool position, the vacuum is fighting against the spring & oscillating against the spring. I wouldn't know if there is an adjustment problem or if there is insufficient vacuum available to hold the flapper against the spring. Just speculation. You could put a vacuum gage on the disconnected line & see what is happening while driving. Someone who is familiar with the car design quirks may be able to help. I doubt if you are the only one that it has happened to.
J TR4/4A Exhaust a tad too loud... Triumph 6
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
J MGB 73 getting loud squeal with acceleration MG 11
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Jim_Gruber In need of a really loud horn Spridgets 13
TEM666666 Exhaust loud popping: Lean? Rich? Fuel? What else? Spridgets 25
F TR2/3/3A Strange Loud Noise Triumph 11
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
AH67 loud enguine- valve like Austin Healey 18
AngliaGT Tossing Out Old Issues of Sports Car/The Wheel/Loud Pedal Racing 1
RAC68 Loud Trans Scrapping Noise Austin Healey 9
7 General TR way to loud in-take noise Triumph 4
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
jlaird Well for crying out loud Spridgets 4
jlaird Thinking out loud, comment pls Spridgets 6
RickB 1.5 M test drive really had me laughing out loud!! Spridgets 14
Stewart Thats one loud powered wheelchair MG 0
tony barnhill 18V Engine Issue [Thinking Out Loud] MG 17
B New fuel pump - loud ticking, now fuel spraying! Austin Healey 33
milemarker60 Spitfire Spit MK-IV Loud Pedal Assy Needed for Project Triumph 4
G LOUD Vibration at about 3000 rpms MG 31
M Loud Exhausts Spridgets 8
A Miss in engine and loud lifter[?] MG 3
S TR6 TR6 front brakes make loud noise Triumph 8
A Why is my car making this noise? Other Cars 5
Popeye TR4/4A Transmission noise - intermittent Triumph 22
AUSMHLY Transmission Noise Austin Healey 11
Gliderman8 TR6 Lever shock noise Triumph 18
LAW75 High-Pitched Noise Austin Healey 13
B High-Torque Starter Rattling Noise Austin Healey 3
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
S TR2/3/3A Noise from clutch area? Triumph 20
P TR6 Clutch pedal click noise Triumph 2
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clutch pedal noise Triumph 2
P TR6 Clunking noise in rear continuing Triumph 39
R Clutch Throwout Bearing Noise? Austin Healey 2
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
Michael Oritt Clutch-related noise Austin Healey 14
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
