I was checking my alignment after putting on about 100miles on my car. I did put the MOSS R&P conversion on the car. While doing the measurements, i noted that the alignment changes as the wheel goes up and down. That is a sign of Bump Steer and the steering arm and spring platform are not parallel. Since the rack cannot be moved down, I will have to change the Rod Ends and use a bump steer kit to raise the steering ends of the R&P. I did try adjusting with a 3/16 washer, but it was not enough and there was not enough threads on the Rod ends to move them any farther. I have left a message for MOSS technical advisement but they have not called back yet.
So you may ask, what does bump steer do to the car? The front of the car may feel like it wants to jump around a little as one of the wheels either drops or goes up not in conjunction with the other wheel. i could feel it when I was driving and decided to fix the issue. Since this is not a race car, it may not be a dangerous issue but it will put stress on the steering and suspension. Also, more wear on the tires.
I should have this fixed by next week and I will report back with the parts and if I can tell the difference while driving.
Jerry
TR3a
Jerry
TR3a
