TR6 Electric Powered Rack & Pinion.
M
malbaby
Thanks...I am aware of the EPAS steering column.
Looking for a suitable EPAS rack and pinion that would fit the TR.
M
malbaby
Thanks "Titanic". if I was to do an EPAS column modification , I would consider the MGF unit due to it's design.
mgedit TR2/3/3A Electric Powered TR3 Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 10
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
T ?Changing BE to SU electric fuel pump Spridgets 8
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
KVH TR4/4A Electric Overdrive Lever Switch Triumph 3
O Electric choke problem. Jaguar 0
